Perpetuum Mobile
  1. Aug 2, 2006 #1
    i had an idea about a perpetual motion machine.
    i have read and saw that my idea is just like Robert Boyle's self-flowing flask.
    http://upload.wikimedia.org/wikipedia/commons/3/3b/Boyle'sSelfFlowingFlask.png
    from what i read this machine who by my idea should let the water move for eternity is not working because it doesn't follow the rules of thermodinamics.
    I didn't really understand this explanation,does anyone knows what's the problem?
  3. Aug 2, 2006 #2
    FredGarvin
    Both ends of the "device" are at the same pressure. There can not be flow without a pressure differential. Examone what the static pressure will be in the tube and the vessel. Also take a look at how liquid levels work. You'll see some similarity there.
  4. Aug 2, 2006 #3
    Since both ends are open to air pressure, the only thing that can make water flow through the tube is a difference in heights. Only when the output nozzle is lower than the flask water level will the water flow. This is not the case in the drawing, and what will really happen is that the water will fall back down the tube until it is at the same level as the flask water. If the nozzle is held lower than the flask water level, water will flow out the tube, but there will be no way to get it back into the flask without doing work. While this concept can be used to steal gasoline from people's cars, sadly it can't be used to make a perpetual motion machine.
  5. Aug 2, 2006 #4
    NateTG
    Actually, it's also possible to get this to happen if there's a heat difference. Water has weird thermal properties, but any gas will flow up the warm side, and down the cold side of a looped vertical tube if the temperature difference is maintained.
Loading...
Similar Threads for Perpetuum Mobile Date
I Microwave oven is prevents mobile signal? Dec 5, 2016
I How to confirm unit of electron mobility as m^2/(V*S)? Jun 12, 2016
Perpetuum mobile Apr 12, 2006
LoCoE and perpetuum mobile Jan 6, 2006
Perpetuum mobile May 30, 2004
