Mastering Perturbation Theory: A Guide for Nuclear Engineering Students
In summary, perturbation theory is a method used to approximately solve non-linear equations, such as differential or integral equations, by writing the solution as a power series and setting coefficients of the same powers equal. It can be used to solve a variety of problems, including in quantum mechanics and ab initio quantum chemistry, and has been found to provide accurate solutions even when the small parameter epsilon is not actually small.
phrozenfearz
Perturbation Theory Help!
Hello physicsforums.com,
The last two weeks of my nuclear engineering course covered a mathematical topic known as 'perturbation theory'. It was offered as a 'method to solve anything' with; the problem is, however, that nobody in my class understands it.
Basic google searching has not yielded any great results, so I turn to the wise physicsforums.com community to perhaps help give new perspective or recommend some relatively easy to follow readings.
Thanks in advance!
Mathematics news on Phys.org
Well, it's a method to approximately solve anything! Specifically, it is a method to approximately solve non-linear equations, in particular functional equations like differential equations or integral equations. The "WKB" method used in quantum mechanics is a perturbation method.
The basic idea of "perturbation" theory is to write the solution to your problem (typically, a differential equation or integral equation although it will work for other kinds of problems) as a power series, [itex]y= y_0+ \epsilon y_1+ \epsilon^2 y_2+ \cdot\cdot\cdot [/itex] where "[itex]\epsilon[/itex]" is some small number inherent in your problem. Write out both sides of your equation as power series in [itex]\epsilon[/itex] and set coefficients of the same powers of [itex]\epsilon[/itex] equal. The [itex]\epsilon^0[/itex] term gives the solution to the approximate linear problem, y_0, and the other equations will give solutions in terms of previous solutions- that is, [itex]y_1[/itex], [itex]y_2[/itex] in terms of [itex]y_0[/itex] and [itex]y_1[/itex], etc.
Here's a trivial example: Imagine that we know how to solve equations of the form [itex]x^2= a[/itex] by just taking the square root but we don't know the "quadratic formula".
Now, we want to solve the equation [itex]x^2+ \epsilon x- 4= 0[/itex] where [itex]\epsilon[/itex] is a very, very small (positive) number. We could argue that since [itex]\epsilon[/itex] is small, that equation is very nearly [itex]x^2= 4[/itex] which has solutions 2 and -2 and so our equation must have solutions very close to 2 and -2.
Is that true? If it is, how could we prove it is true? And how could we use that information to get a better approximation to the true solution?
Let [itex]x= x_0+ x_1\epsilon+ x_2\epsilon^2+ \cdot\cdot\cdot[/itex], a power series in [itex]\epsilon[/itex]. We will assume that [itex]\epsilon[/itex] is small enough that we can ignore [itex]\epsilon^3[/itex] (assuming that [itex]\epsilon[/itex] was small enough to ignore [itex]\epsilon^1[/itex] would give y_0 the linear solution).
If [itex]x= x_0+ x_1\epsilon+ x_2\epsilon^2[/itex], then [itex]x^2= x_0^+ 2x_0x_1\epsilon+ 2x_0x_2\epsilon^2+ x_1^2\epsilon^2[/itex] where I have dropped the terms [itex]2x_1x_2\epsilon^3[/itex] and [itex]x_2^2\epsilon^4[/itex] since they are of higher than second dergee.
[itex]x^2+\epsilon x- 4[/itex], then is [itex] x_0^2+ 2x_0x_1\epsilon+ 2x_0x_2\epsilon^2+ x_1^2\epsilon^2+ x_0\epsilon+ x_1\epsilon^2- 4[/itex] where I have dropped the term [itex]x_2\epsilon^3[/itex] from [itex]\epsilon x[/itex] as it is, again, of higher than degree 2.
The equation becomes [itex](x_0^2- 4)+ (2x_0x_1+ x_0)\epsilon+ (2x_0x_2+ x_1^2)\epsilon^2= 0[/itex]. Equating corresponding components, we have [itex]x_0^2- 4= 0[/itex], [itex]2x_0x_1+ x_0= x_0(2x_1+ 1)= 0[/itex] and [itex]2x_0x_2+ x_2^2= 0[/itex].
[itex]x_0^2- 4= 0[/itex] gives [itex]x_0= 2[/itex] or [itex]x_0= -2[/itex]. Since that is not 0, we can divide both sides of [itex]x_0(2x_1+ 1)= 0[/itex] by x_0 and get [itex]x_1= -\frac{1}{2}[/itex] for both values of [itex]x_0[/itex].
If [itex]x_0= 2[/itex] and [itex]x_1= -1/2[/itex], then the third equation is [itex]4x_2+ \frac{1}{4}= 0[/itex] so [itex]x_2= -1/16[/itex].
If [itex]x_0= -2[/itex] and [iterx]x_1= -1/2[/itex], then the third equation is [itex]-4x_2+ \frac{1}{4}= 0[/itex] so [itex]x_2= 1/16[/itex].
That is, our two solutions are [itex]x= 2- (1/2)\epsilon- (1/16)\epsilon^2[/itex] and [itex]x= -2- (1/2)\epsilon+ (1/16)\epsilon^2[/itex].
If, for example, [itex]\epsilon= .001[/itex], then those solutions are [itex]2- .0005- 0.0000000625= 1.9994999375[/itex] and [itex]-2- .0005+ 0.0000000625= -2.0004999375.
We can use the quadratic formula (which we were pretending we did not know) to actually solve [itex]x^2+ .001x- 4= 0[/itex], getting [itex]x= (-.001\pm\sqrt{0.000001+ 16})/2[/quote] which gives x= 1.99950006 and -2.00050006 so what we got using "perturbation theory" was certainly better than 2 and -2 and also show that 2 and -2 are good first approximations.
A equation of the form [itex]\epsilon x^2+ 2x- 4= 0[/itex] is a much harder problem. Here, just ignoring [itex]\epsilon[/itex], the equation becomes 2x- 4= 0 which has the single solution x= 2 while we expect a quadratic equation like this to have two solutions. For this problem we need "singular perturbation" which is a whole different story!
thanks for your help!
I had an additional question to what you have explained. I have used the perturbation method for solving a set of non-linear differential equations where [tex]\epsilon[/tex] was not small, however the terms [tex]x_0,x_1,x_2[/tex]...etc. get progressively smaller.
I have worked out the equations and they seem to match up quite accurately to the solution found by using ode45 in MATLAB (while having time-varying parameters in the function).
I am trying to find some sort of reassurance that this is ok. Everything that I have found all suggests that epsilon must be small.
Many of the ab initio quantum chemistry methods use perturbation theory directly or are closely related methods. Møller–Plesset perturbation theory uses the difference between the Hartree–Fock Hamiltonian and the exact non-relativistic Hamiltonian as the perturbation. The zero-order energy is the sum of orbital energies. The first-order energy is the Hartree–Fock energy and electron correlation is included at second-order or higher. Calculations to second, third or fourth order are very common and the code is included in most ab initio quantum chemistry programs. A related but more accurate method is the coupled cluster method.
Dear student,
I am glad to hear that your course covers perturbation theory, as it is an important tool for solving problems in nuclear engineering. However, I understand that it can be a difficult topic to grasp at first. My recommendation would be to start by thoroughly reviewing the basics of linear algebra and calculus. These are the foundation for perturbation theory and having a strong understanding of them will make it easier to understand the concepts and techniques involved.
Additionally, I suggest seeking out resources specifically geared towards nuclear engineering students, as they may provide more relevant examples and applications. You can also try reaching out to your professor or classmates for further clarification and discussion on the topic.
Remember, mastering perturbation theory takes time and practice. Don't be discouraged if it doesn't click right away. Keep working at it and seek out help when needed. Good luck!
1. What is Perturbation Theory?
Perturbation theory is a mathematical method used to approximate solutions for problems that are too difficult to solve exactly. It is commonly used in physics and engineering to analyze systems that are slightly different from simpler systems that are already known and understood.
2. How does Perturbation Theory work?
Perturbation theory works by approximating the unknown solution as a series of simpler solutions. The first term in the series is the solution to the simpler system, and each subsequent term adds a correction to account for the perturbations in the original problem. By including more and more terms in the series, the approximation becomes more accurate.
3. When is Perturbation Theory used?
Perturbation theory is used when a system is too complex to solve exactly, but can be approximated as a simpler system with small perturbations. It is commonly used in quantum mechanics, where the exact solution is often unknown due to the complexity of the equations involved.
4. What are the limitations of Perturbation Theory?
Perturbation theory is only accurate when the perturbations in the original problem are small. If the perturbations are too large, the series will not converge and the approximation will become less accurate. Additionally, perturbation theory may not work for highly nonlinear systems or systems that exhibit chaotic behavior.
5. Are there different types of Perturbation Theory?
Yes, there are different types of perturbation theory, including time-independent perturbation theory, time-dependent perturbation theory, and Rayleigh-Schrodinger perturbation theory. Each type is used for different types of problems and has its own set of assumptions and limitations.
  • General Math
  • STEM Academic Advising
  • Science and Math Textbooks
  • Beyond the Standard Models
