PF5 Mathjax Issues
@andrewkirk can you provide an example here of the issue you have found?
BvU
11,952
2,619
BvU
11,952
2,619
I expect ##h=x## and ##y=k.## and what I get to see is h=xh=xh=x and y=ky=ky=k.
andrewkirk
Insights Author
1,354
It's not misbehaving this morning. The following tests work OK. If it happens again I'll not fix the post where it happens, and link to it. The problem I was having is the same as @BvU has reported just above.
Here is a MathJax ##a##, implemented by code:
Code:
##e##
EDIT:The above was a fresh post. Now I will add another MathJax ##e##.
Here is some math format MathJax:
$$e^{i\pi}=0$$
EDIT2: some more MathJax ##1+1=2##.
$$e\times 0 = 0$$
4,195
(if I use h=xh=xh=x and y=ky=ky=k.
Chrome on W10
This might not be a behavior that is specific to PF5. Prior to the recent change, if you Quoted some text with MathJax in it, the text pasted into the reply looked like what is shown above. My workaround was to Quote only the part up to the MathJax, and then click the Edit button to copy the rest of the text verbatim. I would then add in the quoted text, and append/paste the following MathJax text.
BvU
11,952
2,619
DrClaude
Mentor
6,856
2,987
That's because you are a Mentor. The plebes can't edit other's posts :smile:.
The workaround is to click the Reply button, which quotes the entire post correctly, and work with that.
BvU
11,952
2,619
Strange -- when 'reply' is used, it's also enclosed, but it does render:
Want to reply to this thread?
"PF5 Mathjax Issues" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
