PH & Concentration Help - Problem Solving
In summary, the conversation discussed two problems. The first problem involved translating a voltage reading from a pH electrode into pH values using the Nernst equation. The second problem was about preparing a solution with specific concentrations of Ca and C ions. The person providing help recommended using the Nernst equation and converting the natural log to a log base 10. The conversation ended with the person asking for help with the second problem.
kawaiitora
Hi,
I need some help with a few problems. Thanks!
(1) You have a pH Electrode that reports a voltage in
mV, which is proportional to the hydrogen ion concentration
in solution. You also have pH buffers at known pH of say
4, 7 and 10. What do you do to translate the mV reading
into pH values for any given solution with pH between
4 and 10?
(2) You have DI water plus CaCl2 and NaHCO3 salts.
What do you do to prepare a solution with Ca concentration
of 10 mmol/l and total C concentration of 2 mmol/l?
Hi there kawaiitora and welcome to PF,
What are your thoughts on the problems?
Thanks for the quick reply. Sorry, I forgot about that.
(1) I'm thinking that I should use the Nernst equation, but I'm not sure which variation would be the best.
(2) For this one, I'm really not sure how to start. would I need to make up a molecular equation first?
No problem, let's take each problem in turn.
Question One
You should first start with the basic Nernst Equation;
[tex]E = E^{\theta} - \frac{RT}{nF}\cdot\ln Q[/tex]
Now, how many moles of electrons much be transferred to balance the charge on Q (which in this case is the hydrogen ion)? If we also assume standard conditions we have sorted the [itex]\frac{RT}{nF}[/itex] coefficient. Now, the next thing you should do is convert the natural log into a log to the base 10; this involves a little bit of mathematics but is petty straight forward. Next, you will want to express Q in terms of hydrogen ion concentration or activity. After which, all is plain sailing :smile:. Can you go from here?
Yep. Thanks, Hootenanny! Now, I need some help with the second problem...
1. What is the relationship between pH and concentration?
The pH of a solution is a measure of its acidity or basicity. It is related to the concentration of hydrogen ions (H+) in the solution. As the concentration of H+ increases, the pH decreases, making the solution more acidic. Conversely, as the concentration of H+ decreases, the pH increases, making the solution more basic.
2. How do you calculate pH from concentration?
To calculate pH from concentration, you can use the equation pH = -log[H+]. This means you take the negative logarithm of the concentration of hydrogen ions to determine the pH of a solution. For example, if the concentration of H+ is 0.001 mol/L, the pH would be 3.
3. What is the difference between pH and pOH?
pH and pOH are both measures of a solution's acidity or basicity, but they are related to different components. pH measures the concentration of H+ ions, while pOH measures the concentration of OH- ions. The two are related by the equation pH + pOH = 14. A solution with a pH of 7 is neutral, while a solution with a pH less than 7 is acidic and a solution with a pH greater than 7 is basic.
4. How does changing the concentration of a solution affect its pH?
The concentration of a solution directly affects its pH. As the concentration of H+ ions increases, the pH decreases, making the solution more acidic. Conversely, as the concentration of H+ ions decreases, the pH increases, making the solution more basic. This relationship is described by the pH scale, where each whole number change in pH represents a 10-fold change in concentration.
5. How do you use pH and concentration to prepare a solution of a specific pH?
To prepare a solution of a specific pH, you need to determine the concentration of H+ ions needed for that pH. Then, you can use this concentration to calculate the amount of acid or base needed to achieve the desired pH. For example, to prepare a solution of pH 4, you would need a concentration of 0.0001 mol/L of H+ ions. This can be achieved by diluting a stronger acid solution or using a weaker acid solution.
