Homework Help: PH buffer/unbuffered soln please help
  1. Oct 15, 2007 #1
    Im having issues with two parts of this problem, not sure what I'm doing wrong...
    A lake with a surface area of 12.2 acres (1 acre = 4.840 103 yd2) receives 1.67 in. of rain of pH 4.82. (Assume that the acidity of the rain is due to a strong, monoprotic acid.) How many moles of H3O+ are in the rain falling on the lake? I solved that the mols are 32 H3O.
    If the lake is unbuffered (assume pH = 7.00) and its average depth is 9.20 ft before the rain, calculate the pH after the rain has been thoroughly mixed with lake water. (Ignore runoff from the surrounding land.)
    New pH = IM HAVING ISSUES WITH THIS ONE
    Natural waters are typically buffered by dissolved carbonates. If the lake originally contains 0.96 mM HCO3- and 0.28 mM H2CO3, what is the pH of the lake water before and after the rain? (Ignore runoff).
    pH = (before rain) I solved it for 6.90
    pH = (after rain) IM HAVING ISSUES WITH THIS ONE
    any help or guidance would be greatly appreciated.
    2. Relevant equations
    ph=pka + log (a/ha)
    ph=-log[h]
    3. The attempt at a solution
    above
  3. Oct 17, 2007 #2
    Gokul43201
    Staff Emeritus
    You've calculated the moles of H3O+ in the given volume of rainwater from the pH of rainwater. Next, you just need to work backwards. You know the number of moles of H3O+ from rain. Add to this the number of moles of H3O+ in the lake (pH=7), to get the total number of moles of H3O+. With this number and the final volume of the lake, you can calculate the final (unbuffered) pH.
