Homework Help: PH of phosphori acid HELP PLEASE
  1. Oct 15, 2007 #1
    I've been working on this problem and am having issues with some of the problems...
    all we learned was that EQ is pH= pka and at eq and EQ1/2 is pk1+pk2/2 which cant even be applied to this question due to x values.
    I would GREATLY appreciate ANY help/guidance/etc.
    Calculate the pH of 100.0 mL of a 0.110 M phosphoric acid solution being titrated with 0.110 M KOH under the following conditions:
    pH = when no KOH has been added. SOLVED 1.598
    pH = 2.26 when 50.0 mL of KOH has been added. Hint: Ka1 is not small. (*) SOLVED
    pH = when 100.0 mL of KOH has been added.(*)
    pH = when 150.0 mL of KOH has been added.
    pH = when 200.0 mL of KOH has been added.(*)
    pH = when 250.0 mL of KOH has been added. Hint: Ka3 is very small. (*)
    pH = 12.29 when 300.0 mL of KOH has been added. SOLVED
    pH = when 400.0 mL of KOH has been added.
    but all the other 1/2 and eq points im having issues with.. help please!
    2. Relevant equations
    not ph= pka at EQ and not ph= pka+pka2/2 at 1/2eq
    3. The attempt at a solution
    (above)
Draft saved Draft deleted
