Homework Help: Phase Difference - Waves! Help!
  1. Jan 16, 2010 #1
    Phase Difference - Waves! Help! URGENT
    Firstly, can I add that this question is second part of a question , the first part asked me to find the amplitude and wavelength of a wave from a picture, I got these to be a) Amplitude = 8mm - b) Wavelength = 47mm <<<<These two are 100% correct values, I checked the answers at the back of the book.
    So, the question I'm stuck on is "For the waves in figure 4: - determine the phase difference between P and R." I've measured this and the distance between the two is 100% 24.5mm. From this I use the equation:
    the phase difference in radians = 2 x Pi x d/[tex]\lambda[/tex]
    2. Relevant equations
    3. The attempt at a solution
    From the phase difference in radians = 2 x Pi x d/[tex]\lambda[/tex]
    I do, 2 x Pi x 0.0245/0.047 = 3.2757... This gives my answer in rads, but, from here one, do you convert it too degrees, secondly is this correct.
    The correct answer at the back of the book is 180degrees.
  3. Jan 16, 2010 #2
    Re: Phase Difference - Waves! Help! URGENT
    i can only tell you that the last arithmetic is correct
    if you convert it into degrees (3.27*180/pi) you get 187 deg which is 7 deg off by your book result
  4. Jan 16, 2010 #3
    Hmmm, I wonder if maybe you do it to the nearest 90? Because on another question I get 268 the answer is 270 though...?
    EDIT:: For the C1 exam do you guys reckon if it asked for the phase difference in degrees I'd round it to the 180,270 etc or just the normal 3sigfig?
