Antenna Signals: Reflection, Distance and Phase
In summary: Two signals are received with a difference in the phase because the recievers are moving, and the antenna at the cell tower has to add them all up and shift them by the right time in order to get them all in sync.
dervast
133
Hi let's suppore that an antenna creates two signals... The two signal are received from an other antenna but with a main difference. The one of the two signal is reflected in a surface which means that it will travel bigger distance... The two signals are received with a difference in the phase... But what do we mean phase in a signal?
Phase has to do with the shift between corresponding amplitudes between signals.
For example, given signals [itex]A cos (\omega\,t)[/itex] and [itex]A cos (\omega\,t + \theta)[/itex], the phase shift is given by the angle [itex]\theta[/itex].
The phase shift can be spatial, as for sound and water waves, or temporal, as in two EM signals.
Constructive and destructive interference are caused by phase differences.
Thx a lot ... but what do we mean that two signals are received with a difference in the phase?
The differerence is in time
The phase shift is temporal in EM (electromagnetic) signals (as Astronuc explained). Meaning the two signals will arrive at the receiving antenna, at two different times. This is useful information, if you would like to know the direction the signal is coming. But creates a problem when you are trying to utilize information from more than one propagated signal.
This happens (for example) when you use a cell phone and are moving (walking, driving, flying). For the antenna at the cell tower to most efficiently utilize all of your signal, it should add all of your phase-delayed signals and then shift each one by the appropriate time, so that they become reconstructed in the same phase.
If this happens with a TV signal, you will see a ghost image, slightly apart from the original one.
If you listen to an AM broadcast signal at night time, even from a stationary reciever, you may hear a distant broadcast slowly become softer and then louder. You are getting destructive & constructive interference (as Astronuc mentioned) between the ground waves and the ionospheric reflected waves.
1. What is antenna signal reflection?
Antenna signal reflection is the phenomenon in which a portion of the transmitted signal is reflected back towards the transmitter due to changes in the impedance of the transmission medium. This can result in signal loss and distortion.
2. How does distance affect antenna signals?
Distance plays a crucial role in the strength and quality of antenna signals. As the distance between the transmitter and receiver increases, the signal strength decreases due to factors such as free space loss and obstacles in the signal path.
3. What is phase in the context of antenna signals?
Phase in antenna signals refers to the relative timing of the signal in relation to a reference signal. It is measured in degrees and can affect the quality and accuracy of the received signal.
4. How does the shape of an antenna affect its signal transmission?
The shape of an antenna can significantly impact its signal transmission. Different antenna designs have different radiation patterns, which determine the direction and strength of the transmitted signal. The shape also affects the antenna's impedance, which can impact the amount of signal reflection.
5. What measures can be taken to improve antenna signal quality?
There are several steps that can be taken to improve antenna signal quality, including using a higher gain or directional antenna, minimizing signal obstructions, optimizing the antenna's placement and orientation, and using signal amplifiers or repeaters. Additionally, proper maintenance and regular calibration of the antenna can also help improve signal quality.
  • Electrical Engineering
