Photodetector vs. Photosensor: Infrared Light & Point Source
The intensity of light from a point source decreases as the distance increases. And the symbol for an infrared source is usually a lowercase letter "i" with a subscript "r," while the symbol for an infrared detector is a lowercase letter "d" with a subscript "r." In summary, a photo detector and photosensor are typically used interchangeably, but may have different meanings depending on the context. Point source refers to a small, localized source of radiation and the intensity of light from a point source decreases with distance. Infrared sources and detectors are often represented by the symbols "i" and "d" with a subscript "r," respectively.
Alvin
Help! is a photo detector the same as photosensor? can they be specifically for infrared light? and what does point source mean?
Well point source means exactly that. A point-like source of radiation. I'd say they are the same, but it might depend on the context. And yeah, you can usually get a detector specifically for your region of interest in the em spectrum.
so does point sourc light spread out? so that the intensity is inversly proportional to the square of the distance from source?
please could you tell me what is the symbol for a infrared source and detector?
thanks
Adam
yes that's right.
1. What is the difference between a photodetector and a photosensor?
A photodetector is a device that converts light signals into electrical signals, while a photosensor is a device that detects the presence of light. In simpler terms, a photodetector measures the amount of light, while a photosensor simply detects the presence or absence of light.
2. How do photodetectors and photosensors detect infrared light?
Both photodetectors and photosensors use specialized materials, such as semiconductors, that are sensitive to infrared light. When infrared light hits these materials, it causes a change in their electrical properties, which can then be measured or detected by the device.
3. What is the difference between detecting point sources and non-point sources of light?
A point source of light is a single, concentrated source of light, such as a laser beam or a candle flame. A non-point source of light is a broader source of light, such as a light bulb or the sun. Photodetectors and photosensors can be designed to detect either type of light source, but may have different sensitivities and capabilities for each.
4. Can photodetectors and photosensors be used for other types of light besides infrared?
Yes, photodetectors and photosensors can be designed to detect a wide range of wavelengths, including visible light and ultraviolet light. The specific materials and technologies used in the device will determine its sensitivity and range of detection.
5. What are some common applications for photodetectors and photosensors?
Photodetectors and photosensors have a wide range of applications, including in photography, security systems, medical imaging, and optical communication. They are also commonly used in electronic devices, such as smartphones and remote controls, to detect light and adjust screen brightness or activate functions.
  • General Engineering
  • Astronomy and Astrophysics
  • Thermodynamics
