Energy of Photons: An Exploration
In summary: Laser is a device which emits great numbers of IR, visible, or UV photons with the same phase and polarization. (Radio-wave "laser" is called... a "monochromator")
Joe_Limon
I was wondering about the amount of energy in Photons. Do they all have the same amount of energy? Or do they have a base amount which can increase depending on frequency or some other parameter? Also, I have read that photon photon collisions can yield positrons and electrons, both positrons and electrons have mass and thus energy via e=mc^2so does this interaction conserve energy?
Their energy is proportional to their frequency: E=hf. There is no "base amount".
Every interaction conserves energy. The energy of the photons is converted to energy of electrons and positrons - the electron and positron masses are a part of this energy.
Ok, so does that mean there is a minimum frequency for the electron/positron conversion? Also, if you decrease the frequency of a photon to near zero can we still detect it? And do photons exert radiation pressure proportional to their frequency?
1. Yes. 1022 keV, which gives an electron/pair each with rest mass energy 511 keV. Further, to satisfy momentum conservation, this has to occur near a nucleus, so it takes some recoil.
2. Depends on how sensitive your detection system is.
3. Yes, photon momentum is given by p=hf/c
Joe was asking about photon-photon collisions. Those are rare, but they don't need a nucleus.
At some point a description via fields becomes more useful. We can detect fields that are changing extremely slowly, and even static fields. Single-photon detection at very low energies is extremely problematic.
That'll teach me to read the thread properly. o:)
I would imagine low energy detection would be problematic. Static fields is a concept I haven't heard of before, how do we sense them/create them?
With a compass, for example. Or with a voltmeter for electric fields.
Ok, separately that makes sense, but together... are there static electromagnetic fields?
mfb said:
A battery in a magnetic field?
Hmmm ok. Is it possible to induce photons into existence in a vacuum with stationary or oscillating electric and magnetic fields?
A flourescent light tube does that I think.
Well not a vacuum but a gas at very low density.
Indeed. The photons are created entirely by the gas particles, not the vacuum itself.
Variable electromagnetic field *is* light (photons). If you wave a magnet, it emits photons. Very low frequency, low energy radio waves, but still.
Not very strong static electromagnetic field in a vacuum does not produce light.
Ultra-strong static electromagnetic field can produce electron-positron pairs, even in vacuum, and accelerate them, which will make their fields non-static (they are accelerating) and thus emit photons.
That is really cool. If you oscillated a single magnetically charged modlecule could you essentially create a low power laser which you could adjust the frequency?
Ordinary radio transmitters do something similar - they emit their photons by moving charged particles (electrons) back and forth with the desired frequency.
Laser is a device which emits great numbers of IR, visible, or UV photons with the same phase and polarization. (Radio-wave "laser" is called "maser").
If vibrated in a fixed direction could you make a directional maser/laser without the use of optics?
That's exactly what antennas do.
Emission happens mainly orthogonal to the line of motion, however, to focus them you need a parabolic mirror or something similar.
Hmm ok, that changes my understanding substantially, I always assumed the photons released by radio transmission was due to dropping electron orbitals. Thanks!
That process is more typical for the emission of visible light (and some infrared and UV).
Nope. They are due to the back and forth acceleration of the electrons in the metal.
What is the energy of a photon?
The energy of a photon is determined by its wavelength or frequency. This is described by the equation E = hf, where E is the energy in joules, h is Planck's constant (6.626 x 10^-34 J*s), and f is the frequency in hertz.
How is the energy of a photon related to its color?
The energy of a photon is directly proportional to its frequency, and inversely proportional to its wavelength. This means that higher frequency photons have more energy and are associated with colors towards the blue end of the visible light spectrum, while lower frequency photons have less energy and are associated with colors towards the red end of the spectrum.
Can the energy of a photon be measured?
Yes, the energy of a photon can be measured using various methods such as spectroscopy, which involves passing light through a prism or diffraction grating to separate it into its component wavelengths. By measuring the wavelength or frequency of the light, the energy of the photons can be calculated using the aforementioned equation.
How does the energy of a photon affect its behavior?
The energy of a photon determines its behavior, specifically its interactions with matter. Photons with higher energy can cause chemical reactions, while lower energy photons may only cause heating. Additionally, the energy of a photon also affects its ability to penetrate through materials, with higher energy photons being able to penetrate further.
What is the significance of the energy of photons in everyday life?
The energy of photons is essential for a vast array of everyday applications, such as lighting, communication (through radio waves and visible light), and medical imaging. Understanding the energy of photons also allows us to harness solar energy for electricity and fuels, and to develop new technologies in fields such as quantum computing and photovoltaics.
