PHP Random number generator
  • Thread starter jscix
Okay, What im trying to do is create a create a random number generator, that outputs 1 and 2 (coin toss)
From what I understand, the more coin tosses (the more times I generate a random 1 or 2) the more uniform the pattern should be.
EG: After generating a random 1-2 sequence, 1,000,000 times.. i should have 500,000 (1s) and 500,000 (2s).. am I wrong?
Anyway, I'm not sure what Im doing wrong but the more numbers I generate, the more deviation Im getting.
Here is how i'm doing this.. (I know I probably did this all wrong.. if so someone just tell me lols) Cheesy
thank you in advance
Code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="content-type" content="text/html;charset=utf-8" />
<title>Coin Toss</title>
</head>
<html xmlns="http://www.w3.org/1999/xhtml">
<?php
$submit = ($_POST['Toss']);
$values = ($_POST['select']);
if (!$submit) {
<body><center>
<p align="center">Coin Toss Deviation
<form method="post" action="Cointoss.php">
<select name="select">
<option value="none">How many coin tosses?</option>
<option value="one">One Hundred</option>
<option value="two">One Thousand</option>
<option value="three">One-Hundred Thousand</option>
</select><input type="submit" name="Toss" value="Toss" />
</form>
</center></body></p>
</html>
<?php
else {
switch ($values) {
case "none":
die ("Select number of tosses");
break;
case "one":
$total = "100";
break;
case "two":
$total = "1000";
break;
case "three":
$total = "100000";
break;
$dev = 0;
$i = 0;
while ($i < $total) {
$cur = mt_rand(1,2);
//print $i . " = $cur <br>";
if ($cur == "1") {
$dev++;
$one++;
if ($cur == "2") {
$dev--;
$two++;
$i++;
unset ($submit);
print "<center>ones: $one <br>twos: $two<br>";
print "total: " . $dev . " point deviation.<br><br>";
print <<< DUH
Average deviation is 0 points<br>
The more tosses, the lower the deviation should be. (Closer to 0)<br>
DUH;
print "<a href=\"Cointoss.php\">Try Again!</a>";
DrClaude
Mentor
6,807
2,923
It will never be exact.
The problem in the OP is that one has to check the relative, not absolute, deviation.
Want to reply to this thread?
"PHP Random number generator" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
