Optimized Solving a Physics Word Problem - Can You Help?
In summary: Fradial = m(2*g*L*(wradial/w))/rFradial = m(2*g*L*(wradial/w))/rFradial = 1200 N.In summary, Miike012 added two pictures. One of the word problem and one of my diagram. Conservation of kinetic and potential energy, Centripetal acceleration, and decomposition of forces into aligned forces are all explained. The equation for the tension in the rope is also given.
Miike012
1,009
I added two pictures.. One of the word problem and one of my diagram I made..
My work:
1.Wnet = Kf - Ki
-Ugf = Kf... -mgy = mv^2/2 ... - gy = v^2/2
2. x^2 + y^2 = 1780^2
dy/dx = -x/y = velocity (v) at point (x,y)
3. gy = x^2/(2y^2)
4. gy = (1780^2 - y^2)/(2y^2)
... anyways... I know this must be totally wrong..
Can someone please help me answer this problem?
Hi Miike012! :smile:
I have difficulty making sense of what you did.
What do the dots for instance mean in (1)?
And if x and y are coordinates in (2), how did you relate them to a force of 1780 N.
These things have different units and can not be compared...
Anyway, let's start with the relevant equations.
1. Conservation of kinetic and potential energy
2. Centripetal acceleration
Can you write those in formula form?
Next is the decomposition of the forces into aligned forces.
Which forces are there to start with?
1.Wnet = delta K
Ugi - Ugf = Kf - Ki
-Ugf = Kf
-gy = v^2/2
2.a = v^2/r
3. SumFy = Ty - w = (m)(ay)
4. SumFx = Tx = (m)(ax)
Are these correct equations?
"And if x and y are coordinates in (2), how did you relate them to a force of 1780 N."
I related 1780 to (x,y) by saying the end point of tension started at the origin, and because the motion is a circle I gave the following equation...
x^2 + y^2 = 1780^2... which relates it to x and y... would this not be correct?
Miike012 said:
1.Wnet = delta K
Ugi - Ugf = Kf - Ki
-Ugf = Kf
-gy = v^2/2
Right!
Can you write y in terms of theta?
Miike012 said:
2.a = v^2/r
Yes.
You need to relate this to your forces.
Yes, these are correct equations.
However, I suggest you try to find the forces aligned with the rope.
The tension is already aligned.
If you find the component of the weight aligned with the rope, you can find the resulting force along the rope.
The resulting force along the rope must match the centripetal acceleration.
Can it be that you intended Tx^2 + Ty^2 = 1780^2?
x and y would be coordinates that have "meter" as the unit.
1780 is the critical tensional forces that has "Newton" as the unit.
Tx and Ty would be the cartesian force components of the tensional force.
They also have "Newton" as the unit.
3. SumFx = T - wx = (m)(ax)
4. SumFy = -wy = (m)(ay)
like that?
like that?
Yes.
Can you relate those quantities to the angle theta?
While I relate the equations the theta.. I was wondering, how come in some situations in circular motion sometimes the SumFy or SumFx has zero acceleration??
In circular motion the radial force is not zero, or it won't be circular motion.
The tangential force can be zero, and indeed is zero if we're talking about "uniform" circular motion.
Tan(theta) = wx/wy
cos(theta) = (...)/T
Here was my reasoning
Tx should be T
Right.
But I'm getting confused with what x and y stand for exactly.
So I'll use "radial" and "tangential" to keep things clear.
What I was looking for is:
wradial = w sin(θ)
And in your earlier equation for the conservation of energy:
g (L sin(θ)) = v^2/2
These need to be combined with:
Fradial = m acentripetal
Can you work that out?
T- (wy)Tan(theta = (m)(ax)
-(wx)Cot(theta) = (m)(ay)
ok ill work on that
F(radial) = m(2*g*L*(wradial/w))/r
How did you get that?
And what happened to the tensional force T?
im saying x and y because i labeled it with the following axis..
Ah, okay!
sin(θ) = wradial/w
g(L*wradial/w) = v^2/2
v^2 = g(L*wradial/w)(2)
Fradial = m acentripetal = m(v^2/r)
Fradial = m (g(L*wradial/w)(2)/r)
And I am not sure what Fradial is
im guessing its the tension and wradial
Yes.
The total radial force Fradial = T - wradial.
Furthermore this force has to match the radial acceleration. So:
I you can rewrite this in only numbers and theta, you can solve for theta.
Miike012 said:
sin(θ) = wradial/w
Ah, okay.
Note that your r is the radius of the circular motion, which is equal to the length of the rope.
So r=L.
I'm afraid that eliminating theta does not help you forward though.
You should leave the sin(θ) in.
What you do need is that Fradial = T - wradial.
Thank you finally got it...
Sin(theta) = T/(m*g*2 + w)
How in the world did you piece everything together?? I was sitting here thinking I had to use the sum tan-gentle force equation...?
Good!
But there's still something to be done...
What is the relation between m*g and w?
Well, I guess there is a method to it.
First list all your data and relevant equations.
Then consider what the critical condition is.
In this case that the total radial force exceeds the critical threshold.
This will give you a formula.
And then use your data and relevant equations to find the unknown that is asked for.
w= mg
the answer I got was 41 deg
thank you for your help!
You're welcome!
1. What is the process for optimizing solving a physics word problem?
The process for optimizing solving a physics word problem involves several steps. First, carefully read and understand the problem, identifying all given information and what is being asked for. Then, list the relevant equations and principles that can be applied. Next, plug in the given values and solve the equation. Finally, double check your answer and make sure it is reasonable and includes the correct units.
2. How do I know which equations to use when solving a physics word problem?
Choosing the right equation for a physics word problem can be tricky, but it is key to solving the problem accurately. Start by identifying the known variables and what you are solving for. Then, refer to your notes or textbook to find the relevant equation(s) that involve those variables. Be sure to also consider any principles or concepts that may be applicable to the problem.
3. Can you provide an example of optimizing solving a physics word problem?
Sure! Let's say we have a word problem asking for the velocity of a ball that is dropped from a height of 10 meters. We know the acceleration due to gravity is 9.8 m/s^2 and we are solving for the velocity (v). Using the equation v^2 = u^2 + 2as, we can plug in the given values to get v = √(2 x 9.8 x 10) = √196 = 14 m/s. Therefore, the velocity of the ball when it hits the ground is 14 m/s.
4. How can I check the accuracy of my solution when optimizing solving a physics word problem?
There are a few ways to check the accuracy of your solution. First, make sure you have the correct units for your answer. Then, you can try plugging your answer into the original equation to see if it makes sense. Another method is to estimate the answer using mental math, and see if your solution is reasonably close to that estimate. Lastly, you can ask a classmate or teacher to check your work and provide feedback.
5. Can the process for optimizing solving a physics word problem be applied to other subjects?
Yes, the process of breaking down a problem into smaller steps and using relevant equations and principles can be applied to other subjects as well. This method is commonly used in math and science courses, but can also be helpful in fields such as economics, engineering, and even everyday problem-solving. The key is to think critically and logically about the problem at hand.
  • Classical Physics
