Answer:Solve Archer Fish Physic Problem: Find θ0
  • Thread starter sagaradeath
  • Tags
    Physic
In summary, the problem involves an archer fish trying to knock an insect off a twig by squirting water at it. The fish must launch the water droplet at a different angle from the angle at which it sees the insect in order for the droplet to intersect with the insect's path. Using the equations for height, time, and velocity, the solution can be found by finding the angle corresponding to a tan of 1.4.
sagaradeath
Physic Problem. Please Help!
Upon spotting an insect on a twig overhanging water, an archer fish squirts water drops at the insect to knock it into the water. Although the fish sees the insect along a straight-line path at angle φ and distance d, a drop must be launched at a different angle θ0 if its parabolic path is to intersect the insect. If φ = 35.0° and d = 0.900 m what θ0 is required for the drop to be at the top of the parabolic path when it reaches the insect?
Figure:
.........… insect on twig
.........… φ
________________/_______________
......x=o> archer fish
2 years ago
Figure:
.....* insect on twig
.....d /
.../ φ
____/___________
x=o> archer fish
Since the water droplets are at the top of their trajectory you can write:
h = (1/2)gt^2
h = height of insect = 0.9sin(35) = 0.516 m
g = acceleration of gravity = 9.8 m/s^2
t = time to fall from the branch to the water
t^2 = 2h/g
t = SQRT(2h/g)
t = SQRT(2*0.516/9.8) = 0.32450 seconds
Although this is the time to fall from the branch to the water it is also the time it takes to go from the water to the branch and this we can use below.
In order to find the angle phi (P) we can use the fact that tan(P) = v/u where:
v = initial vertical velocity of the water
u = initial horizontal velocity of the water
As far as u it is the horizontal distance divided by the time just calculated so:
horizontal distance = 0.9cos(35) = 0.73723 m
u = 0.73723/0.3245 = 2.27 m/s
We now need v. For this use:
v = gt = (9.8)(0.3245) = 3.1801 m/s
tan(P) = v/u = 3.1801/2.27 = ?
is this right?
this equation should get me the answer but i think I am doing it wrong
tan(P) = v/u = 3.1801/2.27 = 1.4009
can anyone help me with the answer to this problem?
If in fact the problem author did indeed intend the distance d supplied to mean the radial distance from the fish to the insect (as opposed to the horizontal distance), then you're 99% of the way to the solution; Find the angle corresponding to a tan of 1.4.
P = tan^-1(??) = 54.5 deg
The angle theta (T) we seek is the angle the water is shot at. This is the same as the angle the fish sees plus the angle the water is shot at. Thus:
T = 54.5 + 35 = 89.5 deg
Therefore, the angle θ0 required for the drop to be at the top of the parabolic path when it reaches the insect is 89.5 degrees.
1. What is the Archer Fish Physic Problem?
The Archer Fish Physic Problem involves calculating the angle at which an Archer Fish must shoot a water droplet in order to hit its target, taking into account gravity and the distance to the target.
2. How do you solve the Archer Fish Physic Problem?
To solve the Archer Fish Physic Problem, you need to use the laws of physics, specifically the equations for projectile motion. This involves considering the initial velocity of the water droplet, the angle at which it is shot, and the distances involved.
3. What is θ0 in the Archer Fish Physic Problem?
θ0 (theta naught) represents the initial angle at which the Archer Fish shoots the water droplet. This angle is essential in calculating the trajectory of the droplet and determining where it will hit the target.
4. What factors affect the value of θ0 in the Archer Fish Physic Problem?
The value of θ0 is affected by the distance to the target, the gravitational acceleration, and the initial velocity of the water droplet. These factors must be taken into account in order to calculate the correct angle for the Archer Fish to shoot at.
5. Why is the Archer Fish Physic Problem important?
The Archer Fish Physic Problem is important because it helps us understand the complex calculations that animals, like the Archer Fish, are capable of making in order to survive and thrive in their environments. It also demonstrates the principles of projectile motion and can be applied to many real-world scenarios, such as designing projectiles for sports or military use.
