Homework Help: Physical Chem review
  1. Jan 22, 2017 #1
    Calculate Work(w) when 6.5L of an ideal gas at an initial pressure of 34.3atm is expanded or compressed isothermally to a final volume of 34.3L reversibly. Answer in J
    2. Relevant equations
    PV=nRT
    P1V1=P2V2
    w=-nRT In(V2/V1)
    3. The attempt at a solution
    Using w=-nRT In(V2/V1)
    I'm not given mols or T, I know T=constant, since it's isothermal
    Can I use PV=nRT and substitute (PV) in for (nRT) in the equation: w=-nRT In(V2/V1) ?
    If so, what should I use for values of P and V? Final/Initial/delta?
    Io
    PS: This may be in the wrong place, the boundary seems unclear in Chem/Phys or Phys/Chem studies.
  3. Jan 22, 2017 #2
    TSny
    2017 Award
    Welcome to PF!
    Yes
    How does PV in the initial state compare to PV in the final state?
  4. Jan 22, 2017 #3
    P1V1=P2V2 so it doesn't matter which I use as long as P and V are both initial values, or final values. Correct?
    EDIT: Except it's asking for work done, so would it be the Change in Pressure and Volume?
    Io
  5. Jan 22, 2017 #4
    TSny
    2017 Award
    Yes
    nRT is a constant for an isothermal process. At any point along the process, nRT has the same value. The ideal gas law tells us that for any state, nRT = PV. So, nRT for the isothermal process equals PV evaluated for any state along the isothermal process.
    nRT would not correspond to a change in PV.
  6. Jan 22, 2017 #5
    Ah, that makes sense, thanks! How wonderful a change in perspective.
    Io
Have something to add?
Draft saved Draft deleted
