Physical chemistry problem
  • Thread starter tunabeast
tunabeast
27
In a closed system shown in the Figure below (http://i18.tinypic.com/7x1r8mo.jpg"), the piston is freely moving without friction and the system is initially filled with gaseous molecules A only. The mass of a piston is 100 g, its area is 10 cm2 and it is 10 cm from the bottom in the initial state of equilibrium. The pressure outside the system is 1 atm; temperature inside the system is 900 ºC.
a) Calculate the initial number of molecules in the system;
b) Write the equation describing the initial rate of decrease in the number of gaseous
molecules if it is known that molecules A stick to the surface of the piston upon
collision with it (molecules do not stick to any other surfaces; the processes when
gaseous molecules react with a hot substrate surface are the basis of the chemical
vapour deposition technology). Obtain numerical value of the initial rate.
I'm really struggling with where to start on this. I'v been handed a large physical chemistry book and basically been left to my own devices. I understand the problem relates to molecular theory of gasses but could you please steer me in the right direction.
Answers and Replies
chemisttree
704
You can start by determining the pressure exerted by the piston on the confined "Molecules A, 900 C". The external pressure is 1 atm but the piston has mass as well.
Suggested for: Physical chemistry problem
  • Last Post
  • Last Post
Chemistry C1V1 Problem
  • Last Post
  • Last Post
Chemistry Bond length
  • Last Post
  • Last Post
  • Last Post
Chemistry Ideal Gas Problem
  • Last Post
  • Last Post
