Physical Chemistry Problem
  • Thread starter Riles246
Physical Chemistry Problem!!
The total pressure of a mixture of oxygen and hydrogen is 1 atm. The mixture is ignited and the water is removed. The remaining gas is pure hydrogen and exerts a pressure of 0.4 atm when measured at the same values of T and V as the original mixture. What was the composition of the original mixture in mole percent?
I started by using the equation P=nRT/V. Since the V, R and T are the same before and after the reaction I solved the equation for P/n = RT/V so the two equations (for before and after the reaction) could be set equal to each other. Then I got stuck! Please Help!
Answers and Replies
chemisttree
638
In this question you have a mixture of 2 gases at STP conditions. You remove all of one and some of the other in a ratio of 1:2. You are left with excess gas of only one component that has a certain pressure.
PV=nRT works if you know your volume. You will notice that you weren't given volume. You could use any volume and solve the problem but try using V=22.4 liters. It helps.
I don't need to use a volume since the problem states that the volume stays the same. I can set the initial and final states equal to each other by re-arranging the equation to RT/V=P/n. Then the P/n for the initial and final state of the mixtures should equal each other.
chemisttree
638
What do you think 'n' refers to in the initial state? In the final state?
Related Threads on Physical Chemistry Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
