Physical Chemistry Question
In summary, we calculated the electrical energy produced by burning 1 pound of coal to be 24139 W-hrs, assuming an efficiency of 41%. The estimated temperature at which the coal burns is 277°C.
chrisama
The chemical reaction in which C and 02 (Dioxide) form Carbon dioxide produces 4.1 eV (Electron-Volts) of energy per Carbon atom. How much electrical energy, in W-hrs, is produced by burning a pound of coal? Here are all the conversions:
1kg.=2.2 pounds
1 mole of carbon= 12X10^-3 kg
1 mole=6X10^23 atoms
1eV=1.6X10^-19 J
1W/hr==3600J
Take the efficiency of conversion from chemical energy to electrical energy to be N=0.41(N represents efficiency). Compare your answer for the available energy to the one we found in class. Assuming that the cold reservoir for the particular heat engine used is at 20C, estimate the temperature at which the coal burns. Note that these calculations connect energy production in a coal plant all the way to fundamental chemistry and physics.
E (generator)= η (total efficiency) x E (coal). But I'm almost sure that this is the wrong equation.
I'm drawing a blank. Could someone please guide me?
Hello there,
First, let's start by converting the given information into SI units for easier calculation.
1 pound = 0.45359237 kg
1 mole of carbon = 12 x 10^-3 kg = 0.012 kg
1 mole = 6 x 10^23 atoms
1 eV = 1.6 x 10^-19 J
1 W-hr = 3600 J
Now, let's calculate the energy produced per kg of carbon burned:
4.1 eV/atom x 1.6 x 10^-19 J/eV x 6 x 10^23 atoms/mole x 0.012 kg/mole = 4.67 x 10^8 J/kg
Next, we need to calculate the total energy produced by burning 1 pound (0.45359237 kg) of coal:
4.67 x 10^8 J/kg x 0.45359237 kg = 2.12 x 10^8 J
Now, we can use the given efficiency (N = 0.41) to calculate the electrical energy produced:
E (generator) = N x E (coal)
E (generator) = 0.41 x 2.12 x 10^8 J = 8.69 x 10^7 J
To convert this into W-hrs, we divide by 3600 (since 1 W-hr = 3600 J):
8.69 x 10^7 J / 3600 = 24139 W-hrs
This is the electrical energy produced by burning 1 pound of coal. Now, let's compare it to the energy we found in class. I'm not sure what energy you found in class, so I'll just continue with the calculations assuming it is the same as what we found here.
Assuming the cold reservoir is at 20°C, we can use the Carnot efficiency formula to estimate the temperature at which the coal burns:
N = 1 - T_cold/T_hot
0.41 = 1 - (293 K / T_hot)
T_hot = 550 K = 277°C
This means that the coal is burning at a temperature of approximately 277°C.
I hope this helps guide you in solving the problem. Let me know if you have any further questions.
I would approach this problem by first identifying the key information and equations needed to solve it. The given information includes the chemical reaction of C + O2 → CO2, the energy produced per Carbon atom (4.1 eV), and various conversion factors. The equation for converting electrical energy to power (W/hr) is also provided.
The first step would be to convert the given information into a form that can be used in the equation. This would involve converting the given energy per Carbon atom (4.1 eV) into Joules (J), as this is the unit used in the equation for electrical energy. Using the conversion factor of 1eV = 1.6x10^-19 J, we can calculate that 4.1 eV is equivalent to 6.56x10^-19 J.
Next, we need to determine the amount of Carbon atoms in a pound of coal. Using the given conversion factor of 1 mole = 6x10^23 atoms and the information that 1 mole of Carbon = 12x10^-3 kg, we can calculate that there are 1.83x10^23 atoms of Carbon in a pound of coal.
Now, we can use the equation E (generator) = η (total efficiency) x E (coal) to calculate the electrical energy produced by burning a pound of coal. The total efficiency (η) is given as 0.41, so we can plug in the values and solve for E (generator).
E (generator) = 0.41 x (1.83x10^23 atoms) x (6.56x10^-19 J) = 5.08x10^4 J
Next, we need to convert this energy value into power (W/hr). Using the given conversion factor of 1W/hr = 3600 J, we can calculate that 5.08x10^4 J is equivalent to 14.11 W/hr.
Finally, we are asked to estimate the temperature at which the coal burns, assuming a cold reservoir temperature of 20C. This can be done using the Carnot efficiency formula, η = 1 - (Tc/Th). Solving for Th (the hot reservoir temperature), we get Th = Tc/ (1-η) = (293 K)/ (1-0.41) = 497 K.
In conclusion, using the
1. What is physical chemistry?
Physical chemistry is a branch of chemistry that deals with the study of the physical properties and behavior of matter at a molecular and atomic level. It combines principles from physics and chemistry to understand the fundamental principles that govern the behavior of matter.
2. What are some common topics in physical chemistry?
Some common topics in physical chemistry include thermodynamics, kinetics, quantum mechanics, electrochemistry, and spectroscopy. These topics are used to understand the properties and behavior of matter, as well as the chemical reactions and processes that occur.
3. What is the difference between physical chemistry and other branches of chemistry?
Physical chemistry differs from other branches of chemistry in that it focuses on the physical properties and behavior of matter, rather than the composition and reactions of substances. It also uses principles from physics, such as thermodynamics and quantum mechanics, to understand chemical systems.
4. How is physical chemistry used in everyday life?
Physical chemistry plays a significant role in our everyday lives. It is used in the development of new materials, such as plastics and fuels, and in the production of pharmaceuticals. It also helps us understand and control the properties of substances, such as pH levels in household cleaners and the shelf life of food products.
5. What skills are important for studying physical chemistry?
Studying physical chemistry requires a strong foundation in mathematics and physics, as well as a deep understanding of chemistry principles. Critical thinking, problem-solving, and analytical skills are also important, as physical chemistry often involves complex calculations and data analysis.
21K
