Homework Help: Physical Pendulum Problem
  1. Nov 14, 2009 #1
    A uniform disk of radius R = 1.40 m and a 6.0 kg mass has a small hole a distance d from the disk's center that serves as a pivot point.
    What should be the distance d so that this physical pendulum will have the shortest possible period?
    2. Relevant equations
    T = 2π[tex]\sqrt{\frac{I}{MgL}}[/tex]
    3. The attempt at a solution
    Using the parallel axis theorem and moment of inertia of a disk I found the period as:
    T = 2π[tex]\sqrt{\frac{\frac{1.4^{2}}{2}+d^{2}}{9.8d}}[/tex]
    When I find the minimum of this function I get d = 0.990 which is the right answer.
    What I don't understand is why the d isn't zero. Won't T approach zero as d approaches zero?
Draft saved Draft deleted
Loading...
