Is this the correct representation of a physical quadrapole?
  • Thread starter jmtome2
  • Tags
    Physical
In summary, a physical quadrapole is a configuration of four point charges arranged in a specific manner, with equal distances between each charge. It has no monopole moment and a zero dipole moment, making it a good model for a physical quadrapole. The potential energy of this configuration can be calculated by finding the potential of each point and adding them together, or by using the equation U = (q^2/4πε0d)((2/√2)-4) where q is the charge and d is the distance between each charge. The azimuthal and zenith dependencies cannot be eliminated in this calculation.
jmtome2
69
Can anyone verify what a physical quadrapole looks like? I'm trying to do a multipole expansion on one
I understand what a physical dipole is and how to do a multipole extension on one
My best guess is that a physical quadrapole is as follows...
-q---+q
+q----q
with equal distance, d, between each charge? Could someone verify that this is correct
Looks fine to me!:approve:
As you would expect, the total charge is zero, so it has no monopole moment, and you should easily be able to show that the total dipole moment is also zero. Therefor, the potential should be dominated by the quadrapole moment, making it a good model for a physical quadrapole.
If you are studying from Griffiths, he actually gives a short discussion (and a figure!) in the last paragraph of section 3.4.2.
I read it over and thought it was probly that but I don't think he ever labels it as a physical quarapole.
Best method to achieve the full expansion would be to treat the problem as 2 "individual" dipoles with the same theta, and then use the law of cosines, etc...?
That's one idea; just be careful to treat the dipoles as physical dipoles, not ideal dipoles and take note of the fact that they can't both be centered at the origin.
Alternatively, you might choose your origin to be at the center of the charge distribution, and then just write down the potential due to the 4 point charges, and then Taylor expand your expression for large [itex]r[/itex]...Are you asked to find an expression for every term in the expansion, or just up to a certain order in 1/r?
To answer your question, I'm to "calculate the potential energy of a physical linear electric quadrapole"
And in response, I wasn't thinking about the origin being at the center of the quadrapole versus the the center of the dipoles (if I were to do it that way). But if I follow, I can simply do a multipole expansion for each of the charges, right?
Why do any multipole expansion at all? You are asked to find the potential energy of a physical quadrapole; surely you know how to calculate the exact potential energy of 4 point charges in the given arrangement?
Errrr! Yea, no qualification like [tex]r\geq\geq d[/tex]... so just find the potential of each point and add them...
The equation for potential is...
[tex]V=\left(\frac{q}{4\pi\epsilon_0\cdot r}\cdot\hat{r}\right)[/tex]
I'm tired, I'll look at this more in the morning, something to have nightmares about tonight... yay! :)
Get some sleep!:zzz:
Potential is a scalar, not a vector. There is no [itex]\mathbf{\hat{r}}[/itex] in the equation.:wink:
Duh... sry lol... so i get...
[tex]
V=\left(\frac{q}{4\pi\epsilon_0}\right)\cdot\left(\frac{1}{r_{1}}-\frac{1}{r_{2}}+\frac{1}{r_{3}}-\frac{1}{r_{4}}\right)
[/tex]
Like to reduce this into terms of d somehow... working on this, I'll see what comes out, but geometry never was my strong point
ooo and to solve this... set r as the distance from the center to the point, P. Using the law of cosines... it appears as if I'll have the answer in 2 different angular terms, like [tex]\theta[/tex] and [tex]\phi[/tex]... let's see what happens
And that's exactly what happens... so I've got the equations for [tex] r_{1} , r_{2} , r_{3} , r_{4}[/tex] in terms of [tex]\theta[/tex] and [tex]\phi[/tex], how should I get these into a single term of the angle or can I?
No. Look at it this way. With this particular setup, those four lobes result from those four alternating positive and negative charges. There is no getting rid of that azimuthal dependency. There's no getting rid of that zenith dependency, either.
Yea didn't think so, thank you. How do I mark a question resolved?
Don't forget that the question asks for the potential energy of the configuration, not just the potential.:wink:
urrrrrrggh so my entire line of thought was for nothing and the equation becomes
[tex]U=\left(\frac{1}{4\pi\epsilon_0}\right)\left(\frac{q_{1}q_{2}}{d}+\frac{q_{1}q_{3}}{d}+\frac{q_{1}q_{4}}{\sqrt{2} d}+\frac{q_{2}q_{3}}{\sqrt{2} d}+\frac{q_{2}q_{4}}{d}+\frac{q_{3}q_{4}}{d}\right)[/tex]
Final Answer: [tex]U=\left(\frac{q^2}{4\pi\epsilon_0\cdot d}\right)\left(\frac{2}{\sqrt{2}}-4\right)[/tex]
I can do that right?
Looks good to me!:approve:
OK thanks for the heads up :). NOW how do I mark a problem resolved?
1. What is a physical quadrupole?
A physical quadrupole is a type of electromagnetic field that has two positive and two negative charges arranged in a specific configuration. This configuration leads to a complex field that has both electric and magnetic components.
2. How is a physical quadrupole represented?
A physical quadrupole is typically represented using a mathematical model known as a quadrupole moment. This model describes the distribution of charges and their relative positions in the quadrupole.
3. Is this representation of a physical quadrupole accurate?
It depends on the context. The mathematical representation of a physical quadrupole is an idealized model and may not fully capture the complexities of a real-life quadrupole. However, it can provide a good approximation in many cases.
4. What are some real-world applications of quadrupoles?
Quadrupoles have a variety of applications in different fields, including particle accelerators, mass spectrometry, and nuclear magnetic resonance imaging. They are also used in various types of sensors and detectors.
5. How does a physical quadrupole differ from a dipole?
A dipole has two equal and opposite charges, while a quadrupole has four charges that are arranged in a specific configuration. This difference in charge distribution leads to distinct electric and magnetic field patterns for each type of field.
