Physics average speed
Use the data table of displacement time data to get a line of best fit using your Ti-83 calculator. Once you have the equation, graph it so that you can answer the questions 1-5 that follow. Assume that the data below is for an object that is launched vertically upwards.
Time (sec) Displacment (m)
0 9.3
.5 15.075
1.0 18.8
1.5 20.475
2.0 20.1
Using the information above, calculate the average speed for the object from 0.75 sec to 2.9 sec.
I've tried using the distance divided by time, but that hasn't worked, so I think the equation is actually where my problem is. The one I've tried mainly is average speed=change in distance/change in time
Time Displacement
.75 17.193
2.9 14.259
AS=(14.259-17.193)/(2.9-.75)
AS= -1.36
Which isn't right.
Thanks!
Answers and Replies
BruceW
3,611
119
I think your calculation is correct. So maybe there is something wrong with using the calculator's line of best fit as a model for the displacement against time?
I think the calculation might be wrong since -1.36 was correct as the answer for average velocity.
Redbelly98
Staff Emeritus
Insights Author
12,115
151
This hint might help: Speed can never be negative. You need to know the distance (not displacement) traveled during the time interval.
p.s. Would your username be a reference to Cedar Point in Sandusky, Ohio?
Related Threads on Physics average speed
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
20K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
