Physics barometer help
  • Thread starter astru025
astru025
163
Two barometers are made with water and mercury. If the mercury column is 32 in. tall, how tall is the water column?
Not sure where to begin with this question. Someone please help!
Need help really bad.
Answers and Replies
SteamKing
Staff Emeritus
12,809
1,670
Well, do mercury and water have the same density? Which column do you expect would be taller?
NihalSh
199
Ask yourself these questions, it will give you ideas about this question:
What are barometers used for?........what do mercury and water have in different in relevance to this question?
astru025
163
Mercury has a higher density so the water column will be higher. This doesn't really help me much though
adjacent
63
Usually barometers are used to measure the atm. so if you know it,then you can use the equation to calculate the height of water if you know the density of water. Not so difficult. :)
EDIT:Do you know the equation relating height density and all that.If you have studied barometers you should know it.
SteamKing
Staff Emeritus
12,809
1,670
Are you sure about that? What is the density of mercury relative to the density of water?
If a constant pressure P supports a mercury column 32 in. tall, don't you think that the height of the mercury column is somehow related to how dense mercury is?
Suggested for: Physics barometer help
  • Last Post
