Homework Help: Physics in Olympic Basketball
  1. Oct 24, 2012 #1
    Hi, I have a question that I can't finish, because it seems that I'm missing a particular variable. A little help would be very much appreciated.
    Question: An Olympic basketball player shoots towards a basket that is 5.64 m horizontally from her and 3.05 m above the floor. The ball leaves her hand 1.62 m above the floor at an angle of 48.0 deg above the horizontal. What initial speed should she give the ball so that it reaches the basket and hopefully scores?
    This is the variables that I found: xf: 5.64 m xi: 0m Yf:3.05 m yi: 1.62 m deg: 48 G: -9.81 m/s^2
    Am I missing a variable, and if so can you tell me which one and explain how you founded it?
  3. Oct 24, 2012 #2
    I know that this is a two dimisional problem. But it seems like I don't have enough information to apply them to an equation of kineamatics. I need atleast three variables.
    I only have two x values that I can use: they are: x: 5.64 m A: 0 m/s^2
    I only have (three y vaules) technically two y values that I can use and they are: yi: 1.62m yf: 3.05 m G:-9.81
  4. Oct 24, 2012 #3
    jedishrfu
    Staff: Mentor
    i don't think you're missing any variables. Basically you have the ball going up and coming down thru the basket and you have the ball traveling forward at speed vxi = vi * cos(48) and you know the upward speed is vyi = vi * sin(48).
    so now use the equations you have and show some work.
  5. Oct 24, 2012 #4
    Kineamatic Equations
    V = Vo + at
    X - Xo = Vot + .5at2
    v2 = vo2 + 2a(X - Xo)
    X - Xo = .5(Vo + V)t
  6. Oct 24, 2012 #5
    HallsofIvy
    What you have written doesn't mean anything because you haven't defined any of those things. The first thing you need to do is separate ""horizontal" and "vertical" components. What is the vertical acceleration. What is the horizontal acceleration?
  7. Oct 24, 2012 #6
    I tried to get vxi from the equation x=xo+voxT+1/2aT^2
    then I substitued the value into the same equation and got 5.64 m= 5.64 m.
    I am really confused because I was expecting to get a time value. But I got the times canceling out and leaving me with meters=meters instead.
  8. Oct 24, 2012 #7
    vertical acceleration: 9.81 m/s^2 (change to negative value because if gravity and velocity are both positive the ball woudn't come back down), so therefore the gravity will be -9.81 m/s^2.
    horizontal velocity: is zero because air resistance is neglected and this means that it will travel at a constant velocity. Because there isn't no oxygen,carbon,... atoms causing the project tile to declerate.
