Physics Lab Questions: Rubber Band & Force Probe
In summary, the speaker is working on a physics lab and has a question about the effect of a rubber band on a force probe. They initially predicted that the force would not transmit perfectly because the rubber band would pull upwards, but their experimental data proved otherwise. They also ask for help in calculating the percentage of stretch for a rubber band. The expert explains that a percentage is a type of ratio and can be converted to any other denominator. The speaker also asks for clarification on why the prediction was wrong and how to interpret ratios. The expert explains that in a static equilibrium, a force is transmitted by the object to its support and that the total extension is twice the amount of a single rubber band. The expert also mentions that the lower band may
Bashyboy
1,421
Okay, I am working on my physics lab, and I have a few questions regarding it.
First, we are asked to make a prediction: "Predict how you think the presence of a rubber band will affect the force felt by the force probe from the rubber band compared to masses hung directly from the hook?" My lab partners and I thought that the force wouldn't transmit perfectly, because the rubber-band would pull upwards. Our data proved that that wasn't the case. Was are prediction truly wrong? Or, perhaps, did we set something up wrongly?
Also, say I have a rubber band, and I hang it from some hook; I measure its length, and then I put some weight on it, and measure it again. How would I write the amount of stretch as a percentage?
The prediction was truly wrong, as is evident from the experimental data.
The percentage is (stretched length - original length) / (original length) x 100%.
Okay, I am just having a hard time understanding why it was wrong. And why does subtracting the stretched from the original length, then dividing by the original length and multiplying by 100% give you the percentage of stretch. I am sorry, I just don't seem to understand how to interpret ratios.
I am sorry if this information seems evident to you, but I have an dreadful intuition, and I always need to know why; sometimes it is quite bothersome.
For the prediction, intuitively one might think that a force can only be "absorbed" by an acceleration. If a system is in a static equilibrium, then a force acting on one object will be "transmitted" by the object to its support (or "distributed" among multiple supports), where it will be canceled by the reaction force; it is never absorbed by a stationary object.
For the percentage, I am not sure what exactly your problem is. A percentage is a ratio of a special kind, whose denominator is one hundred. A ratio with one denominator can always be converted to an equal ratio with another denominator, thus every ratio can be expressed as a percentage.
So, a rubber band in series will stretch twice the amount of a single rubber band with the same force being applied, is this a correct assumption?
Each band will stretch the amount it would stretch individually - because the lower band stretches and the transmits the same force on the upper band. The total extension is, correctly, twice that. This is why the extension under force is measured as a ratio: it is always the same (for a given force), but the absolute extension depends also on the original length.
Now, what would not make the lower band transmit the force perfectly to the upper band?
Only some other force or motion. The other force might be static friction.
1. How does the length of a rubber band affect its force?
As the length of a rubber band increases, the force it exerts decreases. This is due to the stretching of the rubber, which requires more energy to maintain a longer length and results in a weaker force.
2. How does the thickness of a rubber band affect its force?
The thicker the rubber band, the greater the force it can exert. This is because a thicker band has more material and can store and release more energy when stretched.
3. What is the relationship between the force applied and the distance the rubber band stretches?
The force applied and the distance the rubber band stretches have a direct relationship, meaning that as the force applied increases, the distance the rubber band stretches also increases. This is known as Hooke's Law.
4. How does temperature affect the elasticity of a rubber band?
As temperature increases, the elasticity of a rubber band decreases. This is because heat causes the polymer chains in the rubber to move more freely, making it easier to stretch and reducing its resistance to force.
5. Can the force probe be used to measure the force of other materials besides rubber bands?
Yes, the force probe can be used to measure the force of any material as long as it can be attached to the probe. This includes liquids, gases, and solid objects. However, it is important to consider the range and accuracy of the force probe when measuring forces of different materials.
20K
  • DIY Projects
