What is the ratio of t to r in a set of equations involving p, q, r, s, and t?
  • Thread starter bluepillow
  • Tags
    Ratio
In summary, the person struggles with rearranging the equations and is not sure how to make the text look like an equation. They ask for help and someone tells them to try and make a variable t/r and substitute t in the last equation.
bluepillow
Hey guys, I joined after struggling with a few problems for the past two days. I feel as if the answers are blantanly obvious and I'm just missing the simplest and most important bit(s).
From the set of equations:
p=3q
pr=qs
(1/2)pr2 + (1/2)qs2 = (1/2)qt2
involving the unknowns p, q, r, s, and t, find the value of the ratio t to r.
above
The first thing I did was rearrange the top two equations so I can eliminate certain variables from the 3rd equation.
My possible rearrangements are:
p=3q
p=(qs)/r
q=p/3
q=(pr)/s
r=(qs)/p
s=(pr)/q
After a few trial and error replacements I keep getting complicated equations that are going to take a while to type out. Can someone give me a nudge in the right direction? I can't even wrap my head around this.
Also, how can I make this text actually look like an equation like I've seen in other posts? I'll edit it if someone can tell me how to change it, and I'll add the complicated mess I end up with in the end.
Well, you want to solve the last equation for t/r so see if you can get close to having no t's and r's on the other side and then look for some obvious substitutions to get rid of the t's and r's that are left. I don't know if that helps or not
As for putting equations in your posts, use Latex ([noparse][tex][/tex][/noparse] tags--look at the sigma button that says "Show/Hide Latex Reference")
Thanks for your help. Can someone verify that this looks alright so far? :smile: Thanks lots.
[tex]\frac{1}{2}[/tex]pr2+[tex]\frac{1}{2}[/tex]qs2=[tex]\frac{1}{2}[/tex]qt2
[tex]\frac{1}{2}[/tex]pr2=[tex]\frac{1}{2}[/tex]qt2-[tex]\frac{1}{2}[/tex]qs2
[tex]\frac{(pr ^2)}{2}[/tex]= [tex]\frac{(qt ^2 -qs ^2 )}{2}[/tex]
2(pr2) = 2(qt2-qs2)
pr2 = qt2-qs2
p = [tex]\frac{qt ^2-qs^2}{r^2}[/tex]
p+qs2 = [tex]\frac{qt ^2}{r^2}[/tex]
[tex]\frac{p+qs^2}{q}[/tex] = [tex]\frac{t^2}{r^2}[/tex]
bluepillow, welcome to PF :smile:
It might be easier to define t/r be another variable, say "a":
a = t/r
then you can sub t = a*r in your last equation (EDIT: I mean the last equation in post #1). Work on eliminating everything till you're just left with one equation for "a".
For simple equations, you can copy-and-paste the symbols from here:
https://www.physicsforums.com/blog.php?b=347
For the LaTex stuff, the ∑ button shows up in "Advanced" edit mode. There's also info here:
https://www.physicsforums.com/misc/howtolatex.pdf
Be ready for some weird stuff to happen occasionally with LaTex. Sometimes, your edits will not show up right away, and you'll have to refresh the browser window to see them. And if you have a lot of LaTex equations in a single post, it can take awhile to load because an image file must be generated for each LaTex equation.
If you do a forum-wide search on LaTex or Tex, you'll find more info.
Great! Thank you, I'll try and work on this in the morning.
What is a physics/math ratio problem?
A physics/math ratio problem involves using mathematical concepts to solve problems related to physical phenomena. It requires understanding of both mathematical principles and physical laws.
What are some common examples of physics/math ratio problems?
Examples of physics/math ratio problems include calculating the speed of an object, determining the force required to move an object, and finding the acceleration of a moving body.
What are the steps to solving a physics/math ratio problem?
The steps to solving a physics/math ratio problem typically involve identifying the given values, determining the appropriate mathematical formula, plugging in the values, and solving for the unknown variable. It is also important to check the units of measurement and use the correct unit conversions.
How can I improve my skills in solving physics/math ratio problems?
One way to improve your skills in solving physics/math ratio problems is to practice regularly. You can also seek help from a tutor or study resources, and make sure to fully understand the underlying mathematical concepts and physical laws involved.
What are some common mistakes to avoid when solving physics/math ratio problems?
Some common mistakes to avoid when solving physics/math ratio problems include using incorrect units, not properly converting units, and making calculation errors. It is also important to carefully read and understand the problem before attempting to solve it.
