Homework Help: Physics Problem need help
  1. Sep 22, 2011 #1
    Need Help Now
    A string wound on the rim of a wheel 20 cm in diameter is pulled out at a rate of 75 cm/s. Through how many revolutions will the wheel have turned by the time that 9.0m of string has been unwound? Also how long did it take?
    I really need help with this. If you post, please show all work so I can learn how to do this type of problem.
  3. Sep 22, 2011 #2
    gneill
    Staff: Mentor
    Re: Need Help Now
    joecocobo, welcome to PF.
    You'll have to follow the posting template and show your attempt at working on the problem before help/hints/guidance can be offered.
  4. Sep 22, 2011 #3
    2. Relevant equations
    I don't know any equations to use
    3. The attempt at a solution
    I honestly don't know where to start, to even make an attempt
  5. Sep 22, 2011 #4
    DaveC426913
    You may be overthinking it. For starters, separate the question into its two components. They are not related.
    1] A 9.0m string is wound on the rim of a wheel 20 cm in diameter. How many times is the string wrapped around the wheel?
    Do you know the relationship between the diameter of a circle and its circumference?
    2] How long will a point on the string take, moving at 75cm/s, to travel 9.0m?
    Do you know how to calculate time, given a distance and a velocity?
