Help with Physics w/ Cal 1 & Projectile Motion
In summary: The forces acting on both blocks when they are on the ground are Gravity and the tension in the string.
  • #36
In your system, when you draw the free body diagram, you must choose which way is positive in the coordinate system. The standard is right and up positive, and left and down negative, so any vectors pointing left or down will appear as negative in the scalar equations, while the vectors pointing right and up will appear as positive. This is very important.
  • #37
sb_4000 said:
what am I missing from the formula?
cos(theta) and sin(theta)?
On the hanging block , it's not -g, it's mg ot -mg depending on your sign convention, and you're forgetting may.
On your analysis of the block on the incline you need to use vector's components.
  • #38
what are the vector components again?
  • #39
Well, You need to study vectors and then try another attempt to solve the problem.
  • #40
isnt the vector components like F_x = F*cos(theta) F_y = F*sin(theta)?
  • #41
I'll leave the answer in vector equations. I've to go.
Incline Block:
[tex] \vec{N} + m_{2}\vec{g} + \vec{T} + \vec{F_{f}} = m_{2} \vec{a} [/tex]
Hanging Block:
[tex] m_{1}\vec{g} + \vec{T} = m_{1} \vec{a} [/tex]
Also Remember
[tex] F_{f} = \mu N [/tex]
  • #42
Yes they are, try to see how you can apply them, and see if you can understand the equations i left.
  • #43
Thanks alot..Ill try to figur it out.
  • #44
Oene question, was the second part of my question correcty, it was 4N..the magnitude of tension..thanks again
  • #45
sb4000, did you figure it out?
  • #46
Hi,
Im still having problems solving part a, but I did part b, and I got T=39.19.
  • #47
I will like to see your equations for both blocks.
  • #48
T-m1gsin(theta) = m1a
-t+m2g=m2a
-(m1gsin(theta)+m1a)+m2g=m2a
the I got the acceleration a= m2g-m1gsin(theta)/m1+m2
T=m1gsin(theta)+m1a
this what I used to get T, my teacher had showed us a similar problem..
  • #49
Your equation for the hanging block is correct, but in your equation for the incline block you forgot friction. Find tension using the equation from the hanging block.
