Physics train problem
joshmccraney
104
A piecewise-continuous function models the velocity of a train (fps) as follows:
v(t) =
\begin{cases}
80, & \text{if }\text{t>15} \\
bt+ct^2+dt^3, & \text{if }t\text{ <15}
\end{cases}
How much time does it take the train to travel 5280 ft?
$$(1) vdv=ads$$
$$(2) ds=vdt$$
$$(3) dv=adt$$
where s is distance, v is velocity, t is time, a is acceleration
i have: [itex]5280=80t+15^2b+15^3c+15^4d[/itex] by integrating the piecewise function and using [itex](2)[/itex]. it seems if i can find variables [itex]b,c,d[/itex] i will be done.
i have [itex]80=bt+ct^2+dt^3[/itex] from the continuity of the function (given)
by [itex](3)[/itex] i have [itex]0=b+2*15c+3*15^2d[/itex]
it seems if i can find one more equation for [itex]b,c,d[/itex] i'll be done. i don't think i can use [itex](1)[/itex] as i do not have velocity as a function of distance. ive used the other two equations, so i feel i am close. any help is very appreciated. Thanks!
Answers and Replies
11,405
Your equation 5280=... looks wrong. First, 80t is not the distance travelled after the first 15 seconds. Second, check the integration itself. Third, at that point you cannot know if the 5280 ft will be reached in the first 15 second or not.
i have ##80=bt+ct^2+dt^3## from the continuity of the function (given)
This is not the equation you have. Where (at which time!) are the functions equal?
Is the function piecewise-continuous (which does not help) or piecewise-continuous differentiable?
You could add the requirement that the second derivative is the same at both sides as well, but I don't see this requirement in the problem statement.
Related Threads on Physics train problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
