What is the relationship between the magenta and cyan areas?
  • Thread starter Organic
  • Tags
    Pi
In summary, the conversation discusses the relationship between a circle and its sub-area, which can be found by dividing the circle's area by 3. The conversation also explores the concept of natural numbers and their connection to polygon areas. It asks about the potential usefulness of a mathematical constant and its relation to the CH problem. The conversation also discusses the Archimedian spiral and its area, which is shown to be 1/3 of the area of the circle.
Organic
1,224
Please look at the attached pdf.
You will find in it a circle and some sub-area inside it.
The sub-area exists between the radius and a curve.
The curve is connected to both sides of some radius, and goes through the intersection points that exists between n radii and n-1 inner circles, where each radius is divided by the inner circles to n equal parts.
I have found that the sub-area(magenta) = circle's-area/3(cyan)
1) Can someone show why the magenta area = 1/3 of the cyan area ?
2) We can take any number of inner radii-circles intersection points, and create some border, which is made of straight lines between these points.
By doing this, we get a closed polygon (an area).
Now we take some closed polygon, find the total number of its vertexes and omit 2 (tolal - 2 = n).
By doing this, we get some Natural number n which is conncted to some polygon's area S (please see the attached pdf in the next post, called natural-areas.pdf.pdf).
Through this way we can put in 1-1 correspondence some n with some S.
When have this map, we can ask:
S1 is the area of some polygon, where the number of totel-2=aleph0.
S2 is the area of some polygon, where the number of totel-2=2^aleph0.
3) Is S1 = S2 ?
4) If the answer to (3) is no, then what is the difference between the two magenta areas, and how this difference related to the CH problem ?
5) Do you think that we have here some useful mathematical constant ?
Thank you.
Organic
  • 123.pdf.pdf
Here you can find a pdf file, which shows the connection between some natural number to some area.
  • natural-areas.pdf.pdf
The spiral you have is the "Archimedian" spiral:
r= (R/2 &pi)&theta (R is the radius of the large circle).
It is fairly easy to show that the area is, in fact, (2/3)&pi R2, 1/3 the area of the circle.
Hi HallsofIvy,
Thank you for your reply.
Can you please answer to 3-5 questions ?
Thank you.
Organic
1. What is the formula for "Pi r^2 /3"?
The formula for "Pi r^2 /3" is the formula for the volume of a cone. It is calculated by multiplying the square of the radius by pi and then dividing by 3.
2. How is "Pi r^2 /3" related to the area of a circle?
"Pi r^2 /3" is not directly related to the area of a circle. However, if you multiply the formula by the height of the cone, you will get the formula for the volume of a cylinder, which is related to the area of a circle.
3. Why is "Pi" used in the formula for "Pi r^2 /3"?
"Pi" is used in the formula because it represents the ratio of a circle's circumference to its diameter. It is a constant value that is approximately equal to 3.14159.
4. Can "Pi r^2 /3" be used to calculate the volume of any cone?
Yes, "Pi r^2 /3" can be used to calculate the volume of any cone, as long as the measurements of the radius and height are known.
5. What is the unit of measurement for "Pi r^2 /3"?
The unit of measurement for "Pi r^2 /3" depends on the units used for the radius and height. The resulting volume will be in cubic units, such as cubic inches or cubic centimeters.
  • Linear and Abstract Algebra
  • Precalculus Mathematics Homework Help
  • Set Theory, Logic, Probability, Statistics
  • Classical Physics
