PIPE16 vs PIPE288
  1. May 16, 2014 #1
    Hi,
    How is PIPE288 element type different from its previous version PIPE16 (Ansys v. 14) ? I was reading a tutorial which modeled a cantilever beam with PIPE16 model using real constants to define the pipe thickness and outer thickness. But according to my software version PIPE288 does not require any real constants. So I had to assign those values using SECTYPE and SECDATA commands. The result I got was different from that of the tutorial. I would like to know why?
    Thank You in advance!
  3. May 19, 2014 #2
    nvn
    mechgen: I think the PIPE288 versus PIPE16 answers should be virtually the same, in most cases, unless the cantilever is quite short, or perhaps the displacement is large. If you post your real constants, and your SECDATA, then perhaps someone might be able to check whether they are equivalent. Also, if you post the entire given problem (and given answer), then someone might be able to check the answer.
  4. Oct 20, 2015 #3
    I am also learning the tutorials from University of Albert for this example. After defining the element type by pipe288, I defined the section in Preprocessor-Sections-Pipe-Add (details: Add pipe section with ID: 1, then Add or edit pipe section: section name: pipe1, pipe diameter: 25, wall thickness: 2). Then did everything else like the tutorial said. Finally I got almost the same result as in the tutorial.
    PRINT U NODAL SOLUTION PER NODE
    ***** POST1 NODAL DEGREE OF FREEDOM LISTING *****
    LOAD STEP= 0 SUBSTEP= 1
    TIME= 1.0000 LOAD CASE= 0
    THE FOLLOWING DEGREE OF FREEDOM RESULTS ARE IN THE GLOBAL COORDINATE SYSTEM
    NODE UX UY UZ USUM
    1 0.0000 0.0000 0.0000 0.0000
    2 0.0000 -6.2066 0.0000 6.2066
    3 0.0000 -0.15613E-01 0.0000 0.15613E-01
    4 0.0000 -0.59714E-01 0.0000 0.59714E-01
    5 0.0000 -0.13112 0.0000 0.13112
    6 0.0000 -0.22863 0.0000 0.22863
    7 0.0000 -0.35107 0.0000 0.35107
    8 0.0000 -0.49725 0.0000 0.49725
    9 0.0000 -0.66599 0.0000 0.66599
    10 0.0000 -0.85609 0.0000 0.85609
    11 0.0000 -1.0664 0.0000 1.0664
    12 0.0000 -1.2956 0.0000 1.2956
    13 0.0000 -1.5427 0.0000 1.5427
    14 0.0000 -1.8064 0.0000 1.8064
    15 0.0000 -2.0855 0.0000 2.0855
    16 0.0000 -2.3789 0.0000 2.3789
    17 0.0000 -2.6853 0.0000 2.6853
    18 0.0000 -3.0036 0.0000 3.0036
    19 0.0000 -3.3326 0.0000 3.3326
    20 0.0000 -3.6711 0.0000 3.6711
    21 0.0000 -4.0179 0.0000 4.0179
    22 0.0000 -4.3718 0.0000 4.3718
    23 0.0000 -4.7316 0.0000 4.7316
    24 0.0000 -5.0962 0.0000 5.0962
    25 0.0000 -5.4643 0.0000 5.4643
    26 0.0000 -5.8349 0.0000 5.8349
    MAXIMUM ABSOLUTE VALUES
    NODE 0 2 0 2
    VALUE 0.0000 -6.2066 0.0000 6.2066
  5. Oct 21, 2015 #4
    Sorry, now I know what you mean. It is like, when we use pipe288, the calculated maximum tensile stress by bending is 63.8489 MPa, but it should be 64.9 MPa, like the tutorial said. :(
    The detailed description about this example can be seen here:
    http://www.mece.ualberta.ca/tutorials/ansys/BT/Bike/Bike.html
    Is there anyone who can help us? Thank you very much!
Similar Discussions: PIPE16 vs PIPE288
  1. PE vs MS vs PhD? (Replies: 3)
Loading...
