• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Pitcher throwing a baseball ball
vxr
Problem Statement
A pitcher throws a baseball of mass m = 0.15 kg accelerating it from rest to velocity v = 60km/h. Estimate the force exerted by the pitcher on the ball. If needed, make a reasonable assumption for the distance over which the pitcher accelerates the ball.
F = ma
Hello. I have just started studying physics. Can someone explain to me how can I type in formulas here using Tex for nicer formatting?
I suppose the force is F = ma.
Question is: what is a?
The starting throw angle is not mentioned, I suppose this task has to be related to gravity. All I know is the mass of the ball and velocity 60 km/h which is I suppose final velocity the ball has just before it hits the ground.
I do know calculus and I heard that acceleration is derivative of velocity. Just not sure how to apply derivation in here as I kind of never solved any physics task before.
Thanks for tips.
18,875
3,659
Is this just a problem you invented yourself, or is it out of some textbook?
vxr
It's a task the teacher provided us with at our first physics class. I double checked and I've rewritten it correctly.
gneill
Mentor
20,487
2,608
You might want to think about what other kinematic formulas might be helpful here. Remember that you first need to estimate the distance through which the throw acts, so a kinematic formula involving distance and the other things you are given should prove useful.
Reactions: vxr
18,875
3,659
Are you allowed to specify/estimate the amount of time the force is applied?
Reactions: vxr
PeroK
Insights Author
2018 Award
9,095
3,279
You could ask your teacher a question:
Does he/she think a constant force would be applied in this case?
You could give him/her a hint: is there a relationship between power, force and velocity?
Reactions: vxr
vxr
Thank you all, your answers gave me some context on how should I approach physics problems and what kind of questions I should be asking myself.
I will attempt easier problems.
haruspex
Insights Author
2018 Award
30,857
4,456
Your teacher must want you to assume the force is constant. That allows you to use the SUVAT equations to find the acceleration from the initial and final velocities and the distance over which the force is applied.
Alternatively, your teacher is under the mistaken impression that you can find the average of a varying force by equating energy as force x distance with gained KE. That does not give average force, which is defined as change in momentum divided by time.
Reactions: vxr
vxr
I have a small question about horizontal acceleration.
Let's say there's a tall man who throws a ball in parallel to the ground. Because of vertical acceleration (gravitation), the ball eventually falls. Also, the initial velocity is smaller than the final velocity, because of the acceleration I assume.
So the ball accelerates.
My questions:
0. Is the initial velocity = 0 or does it have some value? To me it only makes sense that initial velocity is non-zero positive value. I feel like if the initial velocity was = 0, then the ball would only be able to fall straight down and not move an inch into right --> direction. It simply does not make sense to me that the initial velocity would be 0. I assume the man applies the force onto the ball the moment he releases it from his hand, and at that very moment it gains some initial velocity that is different than 0...
1. Is there any initial horizontal acceleration? What happens with that horizontal acceleration throughout the ball's flight? (is it decreasing? increasing? constant? or there is no horizontal acceleration at all?)
2. Moreover I am curious about this: let's assume vacuum and no gravity at all. The same tall man throws a ball. In my opinion there should not be any acceleration. The velocity should be constant and equal to initial speed. Is this correct?
So if second question is 'true' and there is no acceleration at all, then the answer to the first question should be: no horizontal acceleration at all (or: putting aside gravity, there is no other acceleration).
Thus in my opinion in both cases there is some initial velocity, but no acceleration. (first case there's only gravity acceleration, and no other 'magic' acceleration)
Not sure if these questions make any sense but I'd greatly appreciate some help here.
DrClaude
Mentor
6,820
2,939
Let's say there's a tall man who throws a ball in parallel to the ground. Because of vertical acceleration (gravitation), the ball eventually falls. Also, the initial speed is smaller than the final speed, because of the acceleration I assume.
I'm assuming here that you are discussing what happens once the ball leaves the pitchers hand.
The have an acceleration, you have to a force acting on the ball. What forces can you see opposing the motion of the ball?
In this case, both the speed and the velocity will be constant. (What is the difference between speed and velocity?)
For a real baseball thrown on Earth? Think about the conditions you set in point 2 above.
Reactions: vxr
Want to reply to this thread?
"Pitcher throwing a baseball ball" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
