ambient_88
- 2
A rod with mass M and length L is mounted on a central pivot. A ball is attached at the end of the rod. The rod initially makes an angle [tex]q = 27^{\circ}[/tex] with the horizontal. The rod is released from rest. What is the angular acceleration immediately after the rod is released?2. The attempt at a solution
M = 1.4 kg
m = 0.7 kg
L = 1.2 m
[tex]\sum\tau = I\alpha[/tex]
[tex]\alpha = \frac{\tau}{I}[/tex]
[tex]\tau = F_{g}rcos(q) = (mg)(\frac{L}{2})cos(27^{\circ})[/tex]
[tex]I = (\frac{1}{12})ML^{2} + (M(\frac{L}{2})^{2})[/tex]
[tex]\alpha = \frac{(mg)(\frac{L}{2})cos(27^{\circ})}{(\frac{1}{12})ML^{2} + (M(\frac{L}{2})^{2})}[/tex]
[tex]\alpha = \frac{(0.7kg * 9.81 m/s^{2})(\frac{1.2m}{2})cos(27^{\circ})}{(\frac{1}{12})(1.4 kg)(1.2 m)^{2} + (1.4kg(\frac{1.2 m}{2})^{2})} = \frac{3.67113 \frac{kgm^{2}}{s^{2}}}{0.672 kgm^{2}} = 5.46 \frac{rad}{s^{2}}[/tex]
I believe I did everything correctly, however, the computer is saying I'm not. Would any of you please point out what's wrong with my solution?
Thanks!
