Planar Fluence
Hello everyone,
Suppose a situation where you have a broad plane-parallele beem of electrons wich is perpendiculary incident upon a thin foil wich scatters the e- for an angle X. I did calculus and the ratio of flux density below the foil respect with the foil remove is 1.06. But, What are the ratio of the number of e- per cm2 passing through a plane just behind (and parallel to) the foil to what with the foil removed? I thing the ratio must be 1.06, also.
Help¡
Answers and Replies
12,831
A sketch would help.
Shouldn't this be the result of an integral over the angular distribution?
Why does your flux increase?
As I saw in Introduction to Radiological Physics and Radiation Dosimetry - Attix, these is an event that happens when you are working with a broad beam. Is an excercise from the first chapter (the third excercise). The exercise gives the answers, and I don´t know why is the unity the particles ratio.
Related Threads on Planar Fluence
  • Last Post
  • Last Post
  • Last Post
  • Last Post
