Planck Units: Mass and Length
In summary, while most Planck units are extreme, Mass and Energy are exceptions as the Planck mass is in the middle of the spectrum and divides it into two parts. For small masses/energies, there is a shorter wavelength for higher energy, and for big masses, there is a longer wavelength for higher energy. There is a correspondence between heavy and light masses in terms of length in Planck units, and this mapping may be important. However, there is currently no information about it.
Dmitry67
2,567
I was always puzzled by the fact that while almost all Planck units are extreme (very high or very low), Mass and Energy are exception from that rule. Planck mass is in the ‘middle’ of the spectrum, and it divides the mass spectrum into 2 parts:
  • For small masses/energies m << Mplanck we can define a wavelength corresponding to the energy (E=hv). The higher energy – the shorter wavelength.
  • For big masses we can define Schwarzschild radius Rs which is proportional to mass (and as I noticed in Black Hole physics scientists think in Rs units, substituting R with M). So, the higher energy – the longer wavelength.
So the same length corresponds (in Planck’s sense) to 2 masses: one light and one heavy. And there is also a correspondence (mapping) of heavy masses into light masses and vice versa. Assuming that Planck units are natural such mappings must be important, but so far I haven’t heard anything about it.
This is really weird. Any thoughts? (or URLs?)
This is confusing but you really just need to think about what different physical mass/length scales are. You need to differentiate between the A) total energy of the system B) the typical energy scale of the system. Its only when B) is approaches the Planck scale that we need to start caring about Planck scale physics. In terms of black holes you can think of A) as the mass of the black hole M and B) as the temperature T of the black hole. Large Black holes M>>m_p have T<<m_p where small black holes M~m_p will have a temperature T~m_p.
The concept of Planck units can definitely be confusing at first, especially when it comes to the exceptions of mass and energy. However, there is a logical explanation for why these units seem to contradict the extreme nature of other Planck units.
First, it's important to understand that Planck units are based on fundamental physical constants, such as the speed of light, the gravitational constant, and the Planck constant. These units represent the smallest possible scales at which our current understanding of physics breaks down. This means that they are essentially the building blocks of the universe.
Now, when it comes to mass and energy, they are not considered as extreme in the Planck scale because they are already on a scale that we can comprehend and measure. The Planck mass, for example, is about 0.00002 grams, which is still within the range of our everyday experiences. Similarly, the energy associated with a Planck mass is also within our understanding.
But as you mentioned, there is a correspondence between mass and energy in the Planck scale. This is because they are fundamentally connected through the famous equation E=mc^2. This means that a certain amount of energy can be converted into an equivalent amount of mass, and vice versa. This is why the same length can correspond to both a light and a heavy mass in the Planck scale.
In terms of the mapping of heavy masses into light masses and vice versa, this is likely due to the fact that in the Planck scale, all mass and energy are essentially the same thing. They are all just different manifestations of the underlying fundamental constants. So while it may seem strange, it is actually a natural consequence of the way our universe is structured.
I hope this helps to clarify the concept of Planck units and their relationship to mass and energy. As for further reading, I would suggest looking into quantum mechanics and general relativity, as these are the theories that underpin the concept of Planck units. You can also check out the work of Max Planck, who first proposed the idea of these fundamental units.
1. What are Planck units?
Planck units are a set of natural units that are based on the fundamental constants of nature, including the speed of light, the gravitational constant, and the reduced Planck constant. They are used in theoretical physics and cosmology to better understand the fundamental building blocks of the universe.
2. How are Planck units calculated?
Planck units are calculated using a combination of the fundamental constants of nature, including the speed of light, the gravitational constant, and the reduced Planck constant. These units are then used as reference points to measure other physical quantities, such as mass and length.
3. What is the significance of Planck units?
Planck units are significant because they help us understand the fundamental structure and laws of the universe. They provide a way to measure and compare physical quantities without relying on any human-defined units of measurement. They also play a crucial role in theories such as string theory and quantum gravity.
4. Are Planck units the smallest units of measurement?
Yes, Planck units are considered to be the smallest units of measurement in the universe. This is because they are based on the fundamental constants of nature and cannot be divided any further.
5. How do Planck units relate to other units of measurement?
Planck units are related to other units of measurement through conversion factors. For example, the Planck length is equivalent to about 1.616 x 10^-35 meters, and the Planck mass is equivalent to about 2.176 x 10^-8 kilograms. These conversion factors allow us to understand the scale of Planck units in relation to other units of measurement.
  • Beyond the Standard Models
  • Other Physics Topics
  • Quantum Physics
  • Cosmology
