Understanding Planck's Units: Exploring Dimensions and Fundamental Forces
In summary, Planck's units are a unique way to combine the constants of c, h/2pi, and G to give a unit of time, length, mass, and energy. This unit is defined as one Planck unit and can be expressed in terms of SI units. The dimensions of a human being can also be expressed in terms of Planck dimensions.
faen
140
1. What is the meaning of Planck’s units? Hint: Compare the strength of the 4 fundamental forces.
2. Calculate the Planck’s dimensions as a function of the SI units.
3. What are the dimensions of the human being in terms of Planck dimensions?
Plancks's units defined in terms of the speed of light (c), the quantum of action (h/2pi), and the Newtonian gravitational constant G
strength of electromagnetic force [tex]\alpha = e/(hc/2pi)[/tex]
strength of gravitational force is G
1. I suppose the meaning of the Planck units is that if they're set to unity while calculating a fundamental force (e.g. F=G*m*m/r^2), you wouldn't need a constant (such as G) to get the right number for force. However i can't figure out how I am supposed to compare fundamental force strengths to show that.
2. The constants describing the Planck units are already described in SI units. So i don't understand what I am asked to do then.
3. This question i don't understand at all...
Thanks a lot to whoever helps.
These constants can be combined in a unique way to give something that has the dimensions of a time (try it!). This is called the Planck time or if you want, "one unit of Planck time". The corresponding value can be given in seconds if you use the usual SI values for h bar, c and G.
You can then find what one Planck time is equal to in seconds.
The same thing for "Planck mass", "Planck length" and, if you want, "Planck energy" (which is simply the Planck mass times c^2)
Likewise
So in order to write the Planck units as a function of SI units, do i have to write the Planck length in meters? Or should i just write all the SI units defining the Planck length without calculating how they cancel each other out?
In question 3, are they asking the average Planck length and mass of a human being, or in which dimensions a human being exist in? English isn't my native language :P
I want to make sure that what I wrote is clear.
There is a unique way to combine c, [tex] \hbar [/tex] and G to get something that has the units of a length. This combination is of course independent of the units used for the three constants. This combination is defined to be one Planck unit of length.
So you will have
One Planck unit of length = expression in terms of c, [tex] \hbar [/tex] and G
(Of course, this is quite arbitrary because one could always multiply by any dimensionless constant such as [tex] \pi [/tex], 1/3 etc. But assuming that the dimensionless constant i snot huge or tiny, it would not change by very much the scale involved so we assume that the dimensionless constant is simply one.)
Now, if you plug in the values of c, [tex] \hbar [/tex] and G in SI units, you will obtain the value of the Planck length in meters. So you will have
One Planck unit of length length = x meters
Once you have that, you can estimate the average height of a person in meters and then give the average height in Planck units of length
Allrighty, got it. Thank you very much :-)
Just to be sure; to answer task 2 i have to just write down the Planck length in meters, Planck mass in kg etc? Hard for me to know what answer the teacher expects.
yes, that's the way I interpret the question. One Planck unit of time is how many seconds, one Planck unit of mass is how many kg, etc...
You are welcome. Glad I could help.
1. What are Planck units?
Planck units are a set of natural units that are based on fundamental physical constants, such as the speed of light, the gravitational constant, and the reduced Planck constant.
2. What is the significance of Planck units?
Planck units are important in theoretical physics as they provide a scale at which quantum effects and gravitational effects become comparable. They also allow for the simplification of equations and provide a more fundamental understanding of physical phenomena.
3. How do Planck units relate to dimensions?
Planck units have specific dimensions, such as length, mass, and time, which are derived from the fundamental constants they are based on. This allows for a universal system of measurement that is independent of any arbitrary units.
4. Can Planck units be used to measure everyday objects?
No, Planck units are extremely small and are only relevant in the study of quantum mechanics and general relativity. They are not practical for measuring everyday objects, which are on a much larger scale.
5. Are Planck units universally accepted?
While Planck units are widely used in theoretical physics, they are not universally accepted. Some scientists argue that they are simply a mathematical convenience and do not have any physical significance. However, they have been used successfully in various areas of physics and continue to be a topic of debate.
  • Beyond the Standard Models
  • Quantum Physics
  • Other Physics Topics
  • Quantum Physics
