Plane in Space R^3: Crossing Points & Triple Integral
In summary, the conversation discussed a problem involving a plane in three-dimensional space. The equation for the plane was given as 6x+3y+z=6. The conversation then went on to discuss finding the coordinates for the plane's intersections with the coordinate axes and sketching a triangle with these points as vertices. An equation for the intersection line with the xy-plane was also presented. The second part of the conversation focused on calculating a triple integral for a pyramid restricted by the plane and the three coordinate planes. The process involved integrating with respect to each variable and using the axis intercepts as limits of integration.
chrisdk
Hi, I got following problem. It might contain little language mistakes, since I translated it from danish.
Let P describe that plane in the space [tex]R^{3}[/tex], that is given by the equation [tex]6x+3y+z=6[/tex]
(i) State the coordinates for the planes crossing points with three coordinate axis, and sketch that triangle, which verticies are these three crossing points.
State moreover an equation for plane’s intersection line with xy-plane
(ii) Calculate triple integral
[tex]\iiint\limits_{0} y dV[/tex]
where K is that pyramid, that is restricted by the plane P and three coordinate planes.
i.) to find the intersection with the z axis, set y=x=0; for y intersection, set x=z=0..and so on.
ii.) you have the function P = 6x + 3y + z - 6. Note that dV = dxdydz, so pick one (lets say dz) and integrate with respect to it to get integral(P, z) = 3xz + 3yz/2 + (z^2)/2 - 3z. Now, you do the same thing with respect to x and then y (in whichever order you please).
Finally, if you're looking for the area beneath the pyramid, you simply use the axis intercepts as your limits of integration. Note that if you're not finding the definite integral, then you need to ignore the limits of integration and just add a constant at the end of your final answer.
1. What is a plane in space R^3?
A plane in space R^3 is a two-dimensional flat surface that extends infinitely in three-dimensional space. In mathematical terms, it can be described as a set of points that satisfy a linear equation with three variables.
2. What are crossing points in a plane in space R^3?
Crossing points in a plane in space R^3 are the points where two or more planes intersect or cross each other. These points can be determined by solving the equations of the planes simultaneously.
3. What is a triple integral?
A triple integral is a mathematical operation that involves calculating the volume under a three-dimensional surface. It is represented by three nested integrals and is used to find the volume of irregularly shaped objects in space.
4. How do you find the crossing points of a plane in space R^3 using a triple integral?
To find the crossing points of a plane in space R^3 using a triple integral, you first need to find the equations of the planes that intersect. Then, set up the triple integral by defining the boundaries of the intersection and integrating the equation of the plane over these boundaries. The resulting value will give you the coordinates of the crossing point.
5. What are some real-world applications of plane in space R^3 and triple integrals?
Plane in space R^3 and triple integrals have various applications in fields such as physics, engineering, and computer graphics. They are used to calculate the center of mass of a three-dimensional object, determine the electric potential of a charged body, and create 3D models and animations in computer graphics.
