Calculating the Velocity of Pin P in a Rod A-Rod B System
In summary, the conversation discusses the movement of a pin attached to a collar with two attached rods, A and B, with different angular velocities. Rod A is positioned horizontally while Rod B is angled 30 degrees up from the wall and 500mm below Rod A. The velocity of the pin is determined to be 2.4 m/s, 73.9 degrees down and right, with the help of a diagram provided by Dave. However, there is some confusion with the calculations and the direction and magnitude of the pin's velocity when it is free to move on both rods.
MarkL
34
From B&J Chap 15
Rods A and B are attached to a wall and point to the right.
A collar with pin P moves freely on Rod A.
Rod A is positioned horizontally.
Rod B is 500mm below Rod A and angled 30 degrees up with the wall.
Pin P is attached to a slot in Rod B. Pin P moves freely in the slot.
Determine the velocity of the pin if the angular velocity of:
Rod A is 8 rad/sec clockwise
Rod B is 3 rad/sec clockwise
Answer : 2.4 m/s, 73.9 degrees down and right
I calculated the relative velocity of the pin for each rod separately.
I get the right direction but the wrong magnitude. Go figure.
I have no problem when the pin moves freely on only one rod.
What is the trick when the pin is free to move on both rods.
Thank you
Mark
Can you give me a picture for illustration ?
Howzziss?..
A Rod A P
]o---------------
500mm /
| / Rod B
B /
]o/
Rod A is a circular rod with a circular cylindrical collar that slides left and right along the rod.
Rod B is more or less flat with a slot cut along the length near the end.
The collar has a pin that fits in this slot. This "connects" the rods.
But the collar/pin combo slide freely along both rods.
As the rods swing, the collar, with P, has a velocity and direction.
Some help?
length of Rod A: 0.5*Tan30 = 0.289 m
length of Rod B: 0.5/Cos30 = 0.577 m
v_ap = (8 r/s)*(0.289 m) = 2.31 m/s -- down
v_bp = (3 r/s)*(0.577 m) = 1.73 m/s -- down and 30 degrees right
v_p relative to B(along slot) due to A = 2.31*cos30 = 2 m/s dwn/lft 30deg
v_p relative to A(along A) due to B = 1.731*cos30 = 1.5 m/s to the right
right direction, wrong magnitude!
My picture didn't work. sorry.
Dave's picture is correct except b crosses a.
Thanks Dave
1. How do you calculate the velocity of a pin in a rod system?
In order to calculate the velocity of a pin in a rod system, you will need to know the length and mass of the rod, as well as the position and velocity of the pin at a specific time. You will also need to know any external forces acting on the system. With this information, you can use the equation v = u + at to calculate the velocity, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time.
2. What is the difference between a rod A-Rod B system and a simple pendulum?
A simple pendulum consists of a mass attached to a string or rod that is free to swing back and forth. In a rod A-Rod B system, there are two rods connected at a pivot point, and the movement of the system is more complex and can involve both rotational and translational motion. The calculation of velocity in a simple pendulum is also different, as it only involves the length of the pendulum and the angle of displacement.
3. How does the mass of the rod affect the velocity of the pin?
The mass of the rod will affect the velocity of the pin by changing the system's inertia. A heavier rod will have a greater resistance to changes in motion, and therefore the pin's velocity will be lower compared to a lighter rod. This can also be seen in the equation for calculating velocity, where a higher mass will result in a smaller acceleration.
4. Can the velocity of the pin be negative in a rod A-Rod B system?
Yes, the velocity of the pin can be negative in a rod A-Rod B system. This would indicate that the pin is moving in the opposite direction of the positive direction used in the calculation. Negative velocities can occur if the initial velocity is in the negative direction, or if the pin is slowing down due to external forces.
5. How do external forces affect the velocity of the pin in a rod A-Rod B system?
External forces, such as friction or applied forces, can affect the velocity of the pin in a rod A-Rod B system. These forces can either increase or decrease the velocity depending on the direction and magnitude of the force. To calculate the velocity with external forces, you will need to use the equation F = ma, where F is the net external force, m is the mass of the pin, and a is the acceleration.
