Planetary motion problem
  1. Mar 11, 2013 #1
    At a ertain point between earth and the moon the total gravitation force exted on an object by both planets is 0. The earth - moon distance is 3.84 x 10^5 and the moon has 1.2% of the mass of earth. Where is this point located.
    2. Relevant equations
    3. The attempt at a solution
    So i drew a diagram and put the distance R between the earth and the moon and the object somewhere closer to the moon. I then wrote that the distance from the object from the earth is (R-X). I then said that the distance from the moon to the object was X.
    Sine it says the Gravitational force exerted on the object at a point is the same... i get
    (GmMm)/(X^2) = (GmMe)/(R-X)^2
    i simplify this too
    X^2 = (R-X)^2
    0 = 0.988x^2 - 0.024RX + (0.012)*R^2
    if i put this into the quadratic formula i get values
    x= 0.5
    and x = 9327.44m
    Now if my answer are correct, does this mean that both are answers? so i would say?
    this point is located 9327.44 meters from the moon and 374.672.56 meters from earth.
    and this point is also located
    0.5 meters from the moon and 383999.5 meters from the earth?
    but at this second point it couldn't match my first point cause the force of gravity from the earth would decrease while the force of gravity on the moon would increase so how could the force exerted be the same??? Anyway i would appreciate any help i can get.
  3. Mar 11, 2013 #2
    Taking Me ti be the mass of the Earth, and Mm the mass of the Moon, (GmMm)/(X^2) = (GmMe)/(R-X)^2 is correct. The next step is not: X^2 = (R-X)^2 is incorrect. Me and Mm are different so cannot both disappear.
  4. Mar 11, 2013 #3
    If the two forces were equivalent, that would imply the two forces pull with the same magnitude and in the SAME DIRECTION. If the two forces pulled in the same direction, and were of the same magnitude, the net force wouldn't be zero. The key idea is that the net force is in fact zero; hence, the two forces have to balance each other out (or cancel).
    I hope this helps. If anyone finds fault, please correct me.
  5. Mar 11, 2013 #4
    Staff Emeritus
    You also need to get your units straight. Is the distance from the earth to the moon in feet, meters, miles, furlongs, etc? What about the units of G? What units is the mass of the earth measured in?
  6. Mar 11, 2013 #5
    Yea you're right it hsould have een X^2 =(0.012)*(R-X)^2 cause Mm = 0.012*Me but it was included in that step in calculation of the the next step
  7. Mar 11, 2013 #6
    So If i choose my + direction toward earth.
    i would get Fnet = Fge - Fgm = 0
    Fnet = (GmMe)/(r-x)^2 - (Gm(0.012)*Me)/x^2 = 0
    Fge = Fgm ?
    and solve for this?
  8. Mar 11, 2013 #7
    yea sorry i dont know why i didn't include it in the givens. Everything is in meters for distances. The radius R and X as well in meters. The mass of the earth is in kilograms.
    G is measured by (N*M^2)/Kg^2
    Sorry about not including that in my given statement.
    Re=6.38 x 10^6 meters
    G= 6.67x10^-11 (N*M^2)/kg^2
  9. Mar 11, 2013 #8
    Here is what happens. $$ \frac {M_m} {X^2} = \frac {M_e} {(R - X)^2}
    \frac {(R - X)^2} {X^2} = \frac {M_e} {M_m}
    (\frac {R - X} {X})^2 = \frac {M_e} {M_m}
    \frac R X - 1 = \pm \sqrt {\frac {M_e} {M_m}}
    You need to choose the right sign. Which one is right?
  10. Mar 15, 2013 #9
    The positive sign cause a distance can't be negative? So since this question asks for the Point at which the force of gravitational force exerted on the object is equal, R/X -1 is that point? Or do i solve for that X value, and express the point as a distance from the moon to the object and from the earth to the object?
    x=R/[√(1/0.012) +1]
    therefore the moon is "R/[√(1/0.012) +1]" from the object and the earth is "R - R/[√(1/0.012) +1]" from the object?
    I'm just having a hard time understanding how you consider the exact point.
  11. Mar 15, 2013 #10
    Voko set X as the distance of the point from the moon. Did you understand voko's equations?
  12. Mar 15, 2013 #11
    Recall what R and X are - you defined them, so you should know!
    For R/X - 1 to be negative, R has to be less than X, or one of them has to be negative - is that physically sensible?
  13. Mar 15, 2013 #12
  14. Mar 15, 2013 #13
    R cannot be less than X because i defined X as the smaller portion, and no neither of them would be negative cause they are lengths
    Also thats a cool way of thinking about it, If R is LESS* than x the fraction is less than 1 so it will be negative... cooolio
  15. Mar 15, 2013 #14
    I believe you have a sign wrong there.
  16. Mar 15, 2013 #15
    yessir i put a fix up top when i saw that.
  17. Mar 15, 2013 #16
    Also the Distance R is measured in kilometers... I dont know why i said meters, i must have missread the question.
    So when i solve the quadratic i get
    X1 = 37912.03 KM
    or x2 = -47239.97 KM
  18. Mar 15, 2013 #17
    The negative answer, as you have discovered, is meaningless physically.
Have something to add?
Draft saved Draft deleted
Similar Threads - Planetary motion problem Date
Planetary motion Oct 3, 2017
Planetary motion problem Oct 5, 2013
Momentum Planetary Motion Problem Mar 4, 2013
Planetary Motion Problem Dec 5, 2010
Difficult Planetary motion problem Nov 22, 2010
