• Support PF! Buy your school textbooks, materials and every day products Here!
Planetary spur gear problem!
Hi
I am doing this gear problem, I have attached the question and how I've started this off I am having problems working it all out as the question said I should try and have the casing rotating at a speed of 15-25 rpm.
I have, these gear sizes which were obtained from a manufacturers catalogue.
TB = 36
TC = 24
TD = 40
TE = 80
NX = 100 rpm
NY = 350 rpm
To work out the number of teeth on casing F, from the geometry of the figure
dF/2 = dE/2+dB
so dF= dE + 2dB
dF= 80+ 2(40) = 160 teeth.
Using my my table of motion which I have attached for the speed of gear F, there is a mistake on it as the 2 TC's cancel out to end up y-x*(TB/TF) I have used the input speed for x and the output speed for y so my equation works out as 350-100 * (36/160) = 327.5 rpm this is obviously very wrong. Where have I went wrong? Have I started at the wrong point?
Thanks in advance.
Answers and Replies
Related Threads on Planetary spur gear problem!
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
