Plasma in a Vacuum Reacting to Magnetic Field
In summary, the conversation discusses what happens to a plasma in a vacuum with an even distribution of 50% electrons and 50% protons when an external magnetic field is turned on. The questions revolve around whether the magnetic field will cause currents that cancel out the field within the plasma, if the particles will start moving in circles in opposite directions, and if the plasma will redistribute in alignment with the magnetic field. The expert summarizer provides information on the motion of charged particles in a magnetic field and explains that the details depend on the velocity distribution of the charges. They also mention that the electric field, not the magnetic field, is responsible for ripping apart opposite charges. Overall, it is suggested that the plasma will maintain its composition and not
bueller11
So, assume you have a plasma in a vacuum made of an even distribution of 50% electrons and 50% protons all flowing in one direction with low collision frequency. Then you suddenly turn on an external magnetic field and watch what happens. How will the plasma react?
Will the magnetic field lines cause currents that will cancel the magnetic field out within the plasma? Will the electrons and protons start going in circles in opposite directions? Will the plasma redistribute into currents that align with the magnetic field? Will something else happen?
Why do you feel that the field lines will cause currents that will cancel out the field within the plasma?
Because it seems like the plasma might try to expel the external magnetic field from itself, causing currents to counter the external field and keep whatever field it initially had, internally.
Edit: I'm really confused on what will happen, because it seems like it could do so many things and none stick out in my mind as what will actually happen.
That is why we should attack the questions one after the other. First, what happens to a proton which is moving with some velocity, and you suddenly turn on a magnetic field?
If we answer this question clearly, the rest of the things will follow. How much have you learned about motion of a charged particle in a magnetic field?
It could experience an additional Lorentz force, q*(v x B) (additional to the forces already experienced by particle-particle interactions)
Are you implying that the electrons and protons will start going in circles in opposite directions?
If you try to include particle - particle interactions, the problem becomes intractable by any elementary methods. Your assumption of low collision frequency also implies low density, and I would neglect the inter-particle interaction, at least until we understand the rest of it.
Circular motion in a magnetic field is a very special case, where the velocity is perpendicular to the field. In general, the motion is helical.
Ok, so helical - specifically the axis of the helix (does that make sense?) would be in the direction of the magnetic field? Does that likewise mean the plasma would separate out (into an electron cloud and a proton cloud) or does the plasma try to maintain it's composition?
The magnetic field is indeed the axis of the helix. The radius of the orbit of a charge in a magnetic field is R = mv/qB, where v is the component of the velocity perpendicular to the magnetic field. So a lot of the details you are asking for depends on the velocity distribution of the charges. It is certainly not true that all the particles have the same velocity.
Thanks for answering my questions!
Ok, so particle velocity distributions I don't know a lot about either... Plasma follows a Maxwell distribution, though, right? Assuming that, would the plasma somehow stay a mass of protons and electrons or would it eventually split out into two separate groups, ignoring particle-particle interactions? In other words, is there anything happening in a plasma that would mean the particles would try to rearrange themselves and stay a unit or would the magnetic field ultimately rip the plasma apart?
I don't see the ripping apart happening. It is the electric field that tends to rip opposite charges apart.
And in an evenly distributed plasma of an equal number of positive and negative charges, the E-field should essentially be 0 everywhere?
Well, the average E field, averaged over a reasonably large region, is zero. If you measure the E field close to any of the particles, certainly you will see a large field
Got it. Thanks for your help!
1. What is plasma?
Plasma is the fourth state of matter, in which gas is heated to extremely high temperatures and ionized, forming a collection of charged particles.
2. How does plasma react to a vacuum?
Plasma can exist in a vacuum, as long as there are enough charged particles present to maintain the ionization. However, the properties of the plasma may be affected by the vacuum environment.
3. What happens when plasma is exposed to a magnetic field?
When plasma is exposed to a magnetic field, the charged particles in the plasma experience a force known as the Lorentz force. This can cause the plasma to move and change shape, as well as interact with the magnetic field in other ways.
4. Why is plasma in a vacuum reacting to a magnetic field important?
This phenomenon has many practical applications, such as in fusion reactors and plasma thrusters. Understanding how plasma behaves in a vacuum and in the presence of a magnetic field is crucial for developing and improving these technologies.
5. Can plasma in a vacuum reacting to a magnetic field be controlled?
Yes, with the right equipment and techniques, plasma in a vacuum can be controlled and manipulated in various ways. This is essential for harnessing the potential of plasma for various industrial and scientific purposes.
  • Electromagnetism
  • STEM Academic Advising
