Plastic vs metal gears / parts
In summary, the plastic gears may be able to replace the metal gears in this industrial machinery, but the force and speed are not that great.
Curious007
46
Hello,
I wonder whether I can replace the Metal gears and other parts with Plastic material? If so, what kind of plastic material should I use? There is no heat and the force is also not that great but the speed is.
This is not for toy but industrial machinery, with gear diameter of about 10 inches.
Thank you.
To answer this question properly, you need to do two things (at least):
1) Evaluate the loads on the gears (actual number) at nominal condition and at max condition;
2) Design a plastic gear, and compute the stresses and wear resistance potential.
When both of these are done, you should have an answer to your question.
Maybe, what specifically is the application? The force and speed being great or not is really relative.
Here is what I'm trying to prototype using plastic gears and other components.
1] I guess the load is just to rotate the gear, which initially have mass resistance of 4-5 lb, I guess. Not more than that. I don't see any other load coming in except the tension of the rope/thread from the bobbin.
2] Little difficult for me. Will have to ask an engineer. But considering above machine. I think not much load is there.
But had anyone used the Plastic gear in industry? I'd like to know the kind of plastics I can use. Better/Best etc? Their names? Which would be cheaper than Steel/Iron/Aluminium?
jh0 said:
Of course plastic gears are used in industry. They are good for low loads, can run without lubrication, have dampening properties and are less noisy than steel gears.
This was at the first page when I googled plastic gears:
http://www.gearsolutions.com/article/detail/5621/engineering-principles-for-plastic-gears
Thank you, that was good one.
Can I use the mold to make plastic gear or is there any other technique to create a gear? Like metal gears are made on machine?
Plastic gears can be milled in the same manner as metal ones. Feed rates are greater and production is faster and cheaper.
I do not see why they could not also be made by injection moulding for mass production, if the plastic is suitable and very high precision is not needed for the particular application.
I don't know much about plastics, but I believe that many plastics absorb humidity and the dimensions can change in the process, also thermal expansion is greater than steel, so for very precise gears plastic (even machine milled) could be a problem.
Well for the machine shown in video, these gears are in back side of the machine. One gear is driven by motor and that in turn rotates all gears in clock-anti clockwise fashion alternately, which touch each other. I'll have to calculate the resulting load of all these gears on the driving one and then decide whether plastic or steel. As of now don't know how much load the plastic gears can with stand if they are made up of Nylon - 6 or 66 who has 8 inch diameter and possible largest gear pitch.
1. What are the main differences between plastic and metal gears/parts?
The main difference between plastic and metal gears/parts lies in their material composition. Plastic gears/parts are made from various types of synthetic polymers, while metal gears/parts are typically made from steel, aluminum, or other metal alloys. This results in differences in strength, durability, and cost.
2. Which is better for use in machinery: plastic or metal gears/parts?
The answer to this question depends on the specific application and requirements of the machinery. Plastic gears/parts are lighter, cheaper, and quieter, making them suitable for use in smaller and less demanding machines. Metal gears/parts, on the other hand, are stronger and more durable, making them better suited for heavy-duty machinery that requires high torque and precision.
3. Are plastic gears/parts more prone to wear and tear compared to metal gears/parts?
In general, yes, plastic gears/parts are more prone to wear and tear compared to metal gears/parts. This is because plastic is a softer material and can deform or break more easily under stress or high temperatures. However, with proper design and material selection, plastic gears/parts can still have a long lifespan and perform well in certain applications.
4. What are the advantages and disadvantages of using plastic gears/parts?
The advantages of using plastic gears/parts include lower cost, lightweight, corrosion resistance, and quieter operation. However, plastic gears/parts also have some limitations, such as lower strength and durability compared to metal, and they may not be suitable for high-temperature or high-torque applications.
5. Can plastic and metal gears/parts be used together in the same machinery?
Yes, plastic and metal gears/parts can be used together in the same machinery. In fact, it is quite common for machines to have a combination of plastic and metal gears/parts, with each type being used in areas where they are most suitable. This allows for cost-effective design and can improve the overall performance and lifespan of the machinery.
  • Mechanical Engineering
10K
