• Support PF! Buy your school textbooks, materials and every day products Here!
Please help a blonde out in physics
  • Thread starter divacute2
An airplane has an aluminum antenna attached to its wing that extends 15 m from wingtip to wingtip. The plan is traveling north at 75m/s in a region where Earth's magnetic field has both a vertical component and a northward component. The net maginetic field is at an angle of 55 degrees from horizontal and has a magnitude of 6.0x10-5 T.
a) Indicate the direction of the magnetic force on electrons in the antenna
b) Determine the magnitue of the electric field generated in the antenna
c) Determine the potential difference between the ends of the antenna
d) Indicate which end of the antenna is at higher potential
It is the first day we have started this and I am struggling can someone help please?
Answers and Replies
malawi_glenn
4,782
Show work done. Following the forum rules are essential in order to get help here.
From the rules:
NOTE: You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums.
