Please help FORTRAN
  1. Feb 13, 2012 #1
    Please help !! FORTRAN ..
    IF(NR-51) 200,100,100
    100 JSUM=0
    200 IF(NR.EQ.6 .OR. NR.EQ.7) PRINT 1
    1 FORMAT(1H1)
    In the above given lines from a program.. What does the 4th line intepret ? (200,100,100)
    and what does 1H1 in the format mean ? .. Thank you :)
  3. Feb 13, 2012 #2
  4. Feb 13, 2012 #3
    Re: FORTRAN 95: New to fortran, want to learn how to input a function
    It's an arithmetic if statement, which goes to the first statement number (in this case 200) if the result is negative, second statement number if the result is zero (in this case 100), and the third statement number if the result is positive (in this case also 100). The GOTO(...)IFL is a computed goto statement, where IFL indexes the list of statement numbers in (...).
    The 1H1 means one "Hollerith" character, in this case '1'. It's an old method for specifying characters, you could probably use '1' instead. My guess is that on the machine this code was written for, a '1' as the first character of output on a line cause a page eject. '+' would cause an overwrite. '0' would double space, and a space (' ') would produce a normal line. '/', is probably 'end of record' so '//' should should cause a double space.
    This must be really old code.
  5. Feb 13, 2012 #4
    Staff: Mentor
    Re: Help with Fortran compile error.
    Welcome to PF. You should post your question to only one thread, and wait for an answer there. It is better to start a new thread for your question, since it is not on the specific tpoic of the post where you have piggybacked it.
    I see you already got your answer to the computed IF statement in another thread. For help with other FORTRAN statements I suggest you do a google search. As for the H in the FORMAT statement, I recall that H stands for Hollerith. Here is more detail: "gcc.gnu.org/onlinedocs/.../gfortran/Hollerith-constants-support.html" [Broken]
    Good luck. When experimenting, never hesitate to modify a line of code to investigate how your change causes it to run differently. You'll learn a lot through trial and error; and even better, you'll remember it! :smile:
  6. Feb 13, 2012 #5
    Staff: Mentor
    Re: Please help !! FORTRAN ..
    I've merged multiple replies from different threads, into a single thread.
  7. Feb 14, 2012 #6
    Maybe, but unix still understands this stuff - for example the -f option on the lpr command.
