Homework Help: Please help! Gas problem for assignment!
  1. Oct 25, 2009 #1
    Container A holds an ideal gas at a pressure of 5x10^5 Pa and a temperature of 300 K. It is connected by a thin tube (and closed valve) to container B, with four times the volume of A. Container B holds the same ideal gas at a pressure of 10^5 Pa and a temperature of 400 K. The valve is opened to allow the pressures to equalize. What is the pressure in the two containers? Note: The temperatures in the containers do not go to an equilibrium and both temperatures stay at their original temperatures.
    2. Relevant equations
    PV = nRT (R = 8.31 J/mol*K)
    3. The attempt at a solution
  3. Oct 25, 2009 #2
    Delphi51
    I hesitated to post because I'm not familiar with this problem.
    You might try using your PV = nRT formula. The pressures will equalize so you'll have
    P1 = P2
    where each P = nRT/V.
    You know the R,T and V for each. How will n1 and n2 be related?
  4. Oct 25, 2009 #3
    No relation was given for n1 and n2.
  5. Oct 25, 2009 #4
    Delphi51
    Is n the number of moles or molecules? If so, then you know n1 + n2 equals the n1 + n2 from the original configuration, which you can figure out and get an actual number for.
  6. Oct 25, 2009 #5
    n = number of moles. So the final pressure would equal.
    P = (n1 +n2)RT/V
    but what would T and V be? remember that both containers begin and end with the same temperature.
  7. Oct 25, 2009 #6
    Delphi51
    I think you misunderstood me. I said
    P1 = P2
    n1*R*T1/V1 = n2*R*T2/V2 and n1+n2 = n (known number).
    You know R,T1,V1,T2,V2 so your have unknowns n1 and n2 and two equations relating them. Thus you can find n1 and n2. Then you can go back and use P = n1*R*T1/V1 to find P.
  8. Oct 25, 2009 #7
    Actually V1 and V2 is not given. You only know that V2 is 4 times V1.
  9. Oct 25, 2009 #8
    Delphi51
    That will work - put in "v1" and "4V1" and cancel the V1's.
  10. Oct 25, 2009 #9
    I don't understand how you can find n1 and n2 if you do not have n.
  11. Oct 25, 2009 #10
    Delphi51
    n=PV/(RT) for the original container A + PV/(RT) for the original container B
    Oh, yes you'll have V1's in there - but surely they cancel out when you put the n1 and n2 into n1*R*T1/V1 = n2*R*T2/V2
  12. Oct 25, 2009 #11
    Wow. This question really does not make sense to me. I don't even know how to isolate for either n1 or n2.
  13. Oct 25, 2009 #12
    Delphi51
    =5*V/(R*300) + 1*4V/(R*400)
    = .0267*V/R
    n = n1 + n2 so n2 = .0267*V/R - n1
    sub into n1*R*T1/V1 = n2*R*T2/V2 to get
    n1*R*300/V = (.0267*V/R - n1)*R*400/(4V)
    Take all the n1 terms to the left:
    n1*R*300/V + n1*R*400/(4V) = .0267*V/R*R*400/(4V)
    n1*300 + n1*400/(4) = .0267*V/R*400/(4) divide by R, mult by V
    n1*(300 + 100) = 2.67*V/R
    n1 = .006675*V/R
    P1 = n1*R*T1/V1
    = .006675*V/R*R*300/V
    = 2
    I put the pressure in units of 100 000 Pa so this is really 200 000 Pa.
  14. Oct 25, 2009 #13
    Wow. Thank you. I really appreciate it. Where is the thanks button on this forum so I can thank you? I'm in Grade 12 and I am sure this is not a high school level question. Thank you once again.
