Please help me come up with a function
  • Thread starter hynpf
hynpf
Hi,
I'm trying to come up with a function, but I have no idea how.
Here's my idea of f(x):
f(5000) = 0.07
f(1000) = 0.25
f(900) = 0.28
f(700) = 0.3
f(500) = 0.5
f(200) = 0.8
f(100) = 0.9
f(50) = 0.97
f(1) = 0.99
f(0.5) = 0.999
where 0 < f(x) < 1
as f(x) approaches 0/1, the change becomes less and less noticeable, and becomes closer and closer to 0/1 but never become 0/1.
Thanks!
Answers and Replies
hynpf
Thanks for the input.
I edited my post right before you posted, so here's a summary of characteristics:
f(x) can only be a positive real number between 0 and 1 exclusive.
x can be between 0 exclusive and infinite, but I want f(500) to be around 0.5, and I don't really care what f(x) will be after x = 500.
I don't need a precise function that fits all my sample values; those are just to illustrate what kind of curve the function takes. As long as it satisfies these conditions, I can take any function.
I'm no mathmatician, so I hope I explained this well..
Looks very roughly exponential, of the form [tex]f(x)=e^{-ax}[/tex], a is some real number. You could graph x against [itex]\ln f(x)[/tex] in a spreadsheet like Excel or OpenOffice, and do a linear regression to find a.
EnumaElish
2,327
124
If you put the data into Excel and graph the points (use the wizard); you can right-click on any of the data points and select Insert Trendline. In the Trendline dialog box, first click on its Type tab and select exponential or power, then go to Options tab and check "Display equation" and "Display R-squared" boxes. You can copy and paste the same graph over and over, then use different functional forms in each. You might want to select the functional form that maximizes the R-squared.
matt grime
9,426
0/1 would be 0.
matt grime said:
0/1 would be 0.
He was using incorrect notation to describe the point [tex]\left( 0, 1 \right) \in \mathbb{R}^2[/tex].
Claude Bile
I would suggest perhaps an inverse tan curve, centred at x=500 and offset by an appropriate amount.
Claude.
Suggested for: Please help me come up with a function
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
