Please help me with this Question based on angular momentum .
In summary, the problem involves a uniform rod of length L resting on a frictionless horizontal surface, pivoted about a fixed frictionless axis at one end. It is initially at rest and is hit by a bullet traveling parallel to the surface and perpendicular to the rod with speed v. The bullet becomes embedded in the rod at its center. The question is to find the final angular velocity of the rod. The solution involves considering the rod and bullet as separate bodies and finding their individual moments of inertia at the chosen axis, then adding them together to get the moment of inertia of the combined system.
Abhishekdas
208
Please help me with this Question based on angular momentum...
A uniform rod of length L rests on a frictionless horizontal surface.The rod is pivoted about a fixed frictionless axis at one end.Initially at rest the rod is hit by a bullet traveling parallel to the horizontal surface and perpendicular to the rod with speed v.It hits the rod at the centre and becomes embedded in it.
Mass of rod = 6m
mass of bullet = m
Find the final angular velocity of the rod...?
Impulse*r=Change in angular momentum.
angular momentum abt a point =I*w
I went about by considering the axis as my reference n used d above eqn..
mass of body after impact = 7m..
So, MI of the body about axis = 7mL2/3
my eqn is
mvL/2=(7mL^2*w)/3
I am getting w=3v/14L
ans in buk is 2v/9L...
Thank you...
The moment of inertia of this body should be the moment of inertia of the uniform rod about the axis plus the moment of inertia of the bullet.
Think of the bullet as a point particle of mass m embedded in the center of the rod.
Whenever we consider the Moment of Inertia of a two or more joint bodies about a point, we consider the net moment of inertia as the sum of the MIs of each of the bodies about that point and not the sum of the masses!
So, you tell me what should be the Moment of Inertia of the body about the point of suspension, after the bullet gets embedded in it? (I mean your mistake is in calculating the MI of the final body)
hi abhi (^.^)
>The place where you went wrong is in Calculating Moment of inertia.
>Think again, didn't the formula you used to calculate M.O.I is used for "Uniform" rod .But the system we get after collision isn't uniform {check urself}.
>If u agree with me, then i give you a suggestion :- Think of the rod and particle as separate 'bodies' for calculating M.O.I. ; find out their respective contribution at the chosen axis and then, add these 2 M.O.I.s to get the M.O.I. of "rod + particle" system :D
>Try it >:)
Firstly...Thanks a lot guys for replying...
Now I am going to reply to all of you at once...Coz u all basically mean dat dere is a problem wid my MI formula...
I had a doubt about dat so dat was my error i gues...But stilll
Correct my thinking...im thinking dat d bullet is embedded into it ryt...so doesn't it form a part of the rod? Lyk in questions where dey say the body "sticks" to it i us d formula of MI taking d body's MI separately...coz its lyk its sticking out its head kinda thing...but wen its embedded den isn't it a diff case? Or maybe d rod loses its uniformity and so 7mL^2/3 is invalid...Im still confused ...This embedding park is makin me think lyk d uniformity is distorted n stuff...I dunno...please reply...
Thanks again...
>Hmm this is what i thinks {I cud be wrong But u said to reply} :-
-->Hmm in questions , the particle gets sticked or embedded means the same thing[as much i use myself in many questions].
>So u can use ur "sticking out its head" thinking and then "i us d formula of MI taking d body's MI separately" :D
--->Hmm i will say we can to an approximation take the rod "even after striking " To Be uniform with same mass as before.{Keep the particle out for rod's calculation} .
>So,take the rod separately , apply formula for getting its M.O.I at the desired axis ;
take the particle and find its controbution and just add both And you will get the desired/required M.O.I.
Thanks...lets see what d odrs have to say...Even i think dat d buk wants us to go n think lyk dat...Answer matches by dat ...lol...neway...
1. What is angular momentum?
Angular momentum is a measure of an object's rotational motion around an axis. It is a vector quantity that depends on an object's mass, velocity, and distance from the axis of rotation.
2. How is angular momentum calculated?
Angular momentum is calculated by multiplying an object's moment of inertia (a measure of its resistance to rotation) by its angular velocity (the rate at which it rotates around an axis).
3. What is the conservation of angular momentum?
The conservation of angular momentum states that the total angular momentum of a closed system remains constant, unless acted upon by an external torque. This means that angular momentum cannot be created or destroyed, only transferred between objects.
4. How does angular momentum relate to everyday life?
Angular momentum is present in many everyday activities, such as throwing a ball, riding a bike, or spinning a top. It is also important in understanding the motion of celestial bodies, like planets orbiting the sun.
5. What are some real-world applications of angular momentum?
Angular momentum is used in various fields, such as engineering, physics, and astronomy. It is essential in designing gyroscopes, stabilizing satellites, and predicting the movement of objects in space. It is also used in sports, such as figure skating and diving, to control and manipulate rotational motion.
9K
