Please Help Motion Question
  • Thread starter wickid
Hello,
I have been racking my brains on this one, and I am sure it is an easy question for most. My teacher has been skipping chapters and jumping around in our text a lot and I cannot get the formula to solve this problem. If anyone can help me out with a formula I would be very appreciative. The question is as follows.
A 150-kg pile driver falls from a height of 7.5 m to hit a piling.
What is its spead as it hits the piling.
As I don't have the time it takes to hit the piling, I am unable to tell how fast the pile driver is falling.
I'm hoping this is an easy problem, and in reviewing the chapter I am in, I cannot find a sample problem similar to this, nor a formula that would work. Please help with with a good formula to use to solve this problem.
Answers and Replies
quasar987
Try viewing the problem in terms of the energy of the pile driver. The key equation, as in all conservation of energy problems, is
[tex]\Delta K = -\Delta U[/tex]
It is almost always easier to treat "constant acceleration problems" in terms of energy rather then fiddling and twisting the equations of motion in every direction.
Thank you for your response,
My text doesn't seem to cover that forumula in the energy/work chapter. I did run into formula v=Sq Root(2gh) which would be about 12.1 m/s. When checking the answer in the book, it is 12 m/s but is this an accurate formula to use in the future, or a coinsidence in this problems case?
That equation will definitely work provided that gravity is the only force, you neglect air resistance. It is derived directly from energy considerations, like quasar recommended.
Try deriving it yourself, it follows from the premise that:
The net kinetic energy is a result of a change in potential energy. Algebraically:
[tex] \frac{1}{2} mv^2 = mgh [/tex]
Now solve for v! This works great for freefall (for speeds much less than the escape speed)
Also, solving for h, you can find the height that an object started freefalling from if you know its final velocity.
Energy is very useful when considering such events.
Related Threads on Please Help Motion Question
  • Last Post
  • Last Post
