Please help - viscosity using stokes law
In summary, someone needs help with finding a formula to calculate viscosity of fluids, and is looking for a simple, easy to use formula. They are having trouble finding a good one and need help finding one. There is a website that has a formula, but it is a bit complicated.
carnocs3m5
Hi, I am doing physics coursework on finding viscosity of fluids by dropping a marble into fluids, finding terminal velocity, then using stoke's law to find viscosity. (using density of fluid, sphere, sphere diameter etc). I have completed all the practical, now just the write up
However ... I could really do with someone's help one the formula I would use, has anybody done this before for their coursework? I know some people will say 'just google it,' but I have spent far too long doing so, and right now have dozens of tabs and each formula is a slight variation on the other. I honestly have no idea which is the best/right one (my physics teacher is ill till after the christmas holidays so I can't ask him) ... they all put the viscosity in a different units, some do not give the required unit of density for the calculation (kg/g per cm/m/mm), some have weird units I have never heard of, some use a terminal velocity, some use variable velocity, some involve Brenner’s Law due to the influence of the boundaries of the tube on the sphere, and some from a few university lecture notes go into further complexities!
Is there a simple formula that my measurements can easily 'slot' into that someone can recommend, which will give me results which are not necessarily 100% spot on, but just a simple measure of viscosity that is near the value.
Thanks!
Try this: http://www.engr.uky.edu/~egr101/ml/ML3.pdf
Note, there are two different measures of viscosity, called kinematic viscosity and dynamic viscosity.
See http://www.engineeringtoolbox.com/dynamic-absolute-kinematic-viscosity-d_412.html
for how they are related and their units.
The SI units for viscosity don't have any special names, but the CGS units are named as
poise (kinematic) and stokes (dynamics). The commonly used "practical" units are centipoise and centistokes (= 1/100 or a poise and a stoke).
FWIW the viscosity of water at room temperature is about 1 centipoise, and also 1 centistokes.
Hi
I only know one formula for Stokes' Law
V = (2/9) * ( [tex]\rho[/tex](Sphere) - [tex]\rho[/tex](Fluid) ) *(g/m) * R2
where m is the viscosity of the fluid
This formula was derived using force equilibrium on the falling sphere
Weight = Buoyancy Force + Drag Force
and the units here are SI
check this out : http://en.wikipedia.org/wiki/Stokes'_law
I guess to ignore the boundary effect you should use a relatively big tank(or whatever you are keeping the fluid),I mean use something that its dimensions are bigger than the sphere in order to neglect the boundary effect and to use the previous formula
Hope that helps :)
Hi everyone, thanks for your help!
Using this document (http://www.engr.uky.edu/~egr101/ml/ML3.pdf ), on page 4
Fb+ Fd=mg
where Fd= 6πμVd
and where Fb= 4/3πr^3 × ρ ×g
What are the units I need to use in the formula, as I have seen some densities with g/cm^3, kg/m^3, kg/cm^3 etc.
Also, comparing formulas I have seen some radius measurements subbed into different formulas in m, cm, mm. Again, different variations on the theory use the volume in m^3, cm^3, and also one document I read had g as not as 9.8, but 9800 or 980 (I can't remember) in some other form.
I know how to convert the units, it is just a case of which unit do I need to use in the above formulas to work out absolute (or dynamic) viscosity?
This formula is meant give it to me in Pascal second, am I right?
many thanks!
Why do you want to make it hard for yourself??
As I told you,use the formula I gave you (which is also in that Wikipedia page)
which give you the Dynamic Viscosity
In the SI system the dynamic viscosity units are N s/m2, Pa s or kg/m.s
and for the dimensions:
Density : kg/m3
Gravity : m/s2
Velocity : m/s
Viscosity : kg/m.s
ok, so the formulas on my previous post are just rearranged to give the wiki formula?
and sorry for not paying attention to your post, I read the first one and scrolled to reply, not seeing it!
apologies!
No worries
so is everything cool now :))??
yeah I think so, the wiki formula is just a rearrangement of frictional force combined with the buoyant force balancing the gravitational force. To directly find the viscosity, I can just rearrange the wiki formula, pretty much just swapping the velocity and viscosity's 'position' in the equation.
The only thing ... where does the 'difference in density' bit come from in the wiki formula?
When this is rearranged ...
Fb+ Fd=mg
where Fd= 6πμVd
... have they calculated the 'm' of 'mg' using volume and density, and when that all gets rearranged we get ( density(Sphere) - density(Fluid) ) somehow?
thanks
That's correct as Fb = (4/3)[tex]\Pi[/tex]*R3*[tex]\rho[/tex](fluid)*g
by rearranging the equation Fb + Fd = mg , you will get the difference in density.
Hi, I have completed the experiment, yet now trying to work out a decent viscosity is proving a nightmare, and using my calculator and also http://goo.gl/dt71T, my results for viscosity are always way off. Is there any chance anyone could look over these figures and help me work out which part of my experiment has gone so horribly wrong?!
Ball, diameter 2cm, mass 30g, density roughly 7000kg/m^3
Time to fall (in seconds) 0.8m (80cm) in a tube of the following liquids (time is an average of 10)
Water 1.293
Veg Oil 2.617
Olive Oil 2.792
Motor Oil 4.99
Glycerol 20.77
Syrup 794.85
Corresponding Fluid density
998
915
921
1250
888
1495
The tube diameter is 2.5cm, so is this just too thin compared to the ball for a reliable measure to be calculated?
Thanks! :D
I agree the results look like nonsense. I think you have two big problems with the experiment.
Stokes Law gives the force on a sphere in an infinite volume of fluid, at low velocities. In your case
1. The ball is blocking up 64% of the area of the tube, so the flow pattern will be very different from the assumptions. if you just about the relative areas (64% ball and 36% water) , the water must be flowing upwards past the ball 64/36 = 1.8 times faster than the ball is moving downwards. Stokes assumes that upwards water velocity is zero.
In my PDF link there is an approximate correction formula for this effect
mu_c = mu[1 - 2.104 d/D + 2.09 (d/D)^3 - 0.95 (d/D)^5]
But that is only accurate when d/D is fairly small.
In your case d/D = 2/2.5 = 0.8 and the some of the "correction terms" are bigger than the measured value.
mu_c = mu[1 - 1.68 + 1.07 - .31] = 0.08 mu
The answer of 0.08 is probably nonsense, except that it shows assumptions behind the formulas do not apply.
2. The other problem is your velocity is much too high, at least for water. In fluid dyamics there is an important non-dimensional number called Reynolds number. Its physical meaning is the the ratio of the inertia forces (mass x acceleration) to the viscous forces on an object. For a sphere it is
Re = rho V d / mu
Using the correct value of mu for water (about 0.01 in CGS units) and your measured values,
Re = 1 x 60 x 2 / 0.01 = 12000
Re > 3000 means the fluid flow will be fully turbulent. Unfortunately Stokes Law only applies for completely laminar flow, when Re < 1.
So using a bigger tube won't fix the problem, because you need to reduce the speed by a lot. The way to do that is use a much smaller ball, preferably with a lower density as well. Try a 1mm diameter ball bearing. A small plastic sphere might work even better.
Now you are thinking like a mechanical engineer and not a fluid dynamicist. For pipe flow, the flow is laminar until [itex]$Re_{D} \approx 2300$[/itex] and is fully turbulent typically by [itex]$Re_{D} \approx 4000$[/itex]. That only holds for pipe flow. For external flows, that number is orders of magnitude higher (e.g. transition doesn't occur on an airfoil until well into the millions).
Actually, this flow will be laminar. Stoke's Law applies just fine.
The bigger issue is that the OP is not measuring terminal velocity, he/she is measuring an average velocity from top to bottom. You have to start your time after the ball has reached its terminal velocity or you are measuring the wrong thing. That should happen fairly quickly though.
Edit: Sorry if my Reynolds numbers are showing up funny. The LaTeX interpreter is acting goofy.
Actually I've spent (or mis-spent) quite a lot of my life worrying about external flows round aircraft nacelles and internal flows in engine oil systems. I can successfully identify which is which at least 9 times out of 10. :smile:
You are right that Stokes Law applies to external laminar flow, but you are wrong about the OP's actual experiment, which was done on a pipe with a stonking great flow restrictor and turbulence generator inside it (namely, the ball bearing).
Airfoils are not usually spherical either, so the transition Re for a typical airfoil doesn't apply. Look up a graph of the drag coefficient of a sphere against Re, if you don't believe me.
His experiment is in a "pipe" but the fluid is not moving with respect to that pipe (except in the annulus between the pipe and the sphere). On top of that, the Reynolds number of importance in a pipe flow is that which is based on the pipe diameter. The correlations would be entirely different for Reynolds number based on the ball diameter. The flow will be separated (for most of these cases), but not turbulent.
I realize airfoils are not spherical, and I don't claim that transition Reynolds number would be the same for a sphere. My claim is that an external flow is a fundamentally different phenomenon in many respects, including with respect to transition to turbulence.
I have a very hard time believing that, in this situation, the necessary instabilities would develop and grow fast enough to be turbulent before the sphere has passed. In order for the flow to transition, there needs to be such an instability. It won't be an inviscid instability because there is (as far as I can see) no inflection point in the boundary layer. It won't be a Görtler instability, and in fact, the convex surface would actually stabilize the system. The only remaining 2-D, viscous instability is the Tollmein-Schlicting instability, and those grow very slowly.
I suggest you stop theorizing, get a piece of pipe and a ball bearing, put something in the fluid to visualize the flow pattern, and do the experiment.
And I would suggest you do the same. It won't be turbulent. This isn't a pipe flow problem.
I think I find AlephZero correct
@carnocs3m5 :
I Suggested you before to use something relatively bigger in dimensions than the sphere
2.5 cm & 2 cm are pretty much close don't you think :rolleyes:??
may be you can use a tub(for water of course) and for the other fluids you can use a smaller sphere.
Plus are you sure you are measuring the terminal velocity correctly ?
Do the experiment again and show us the results
I will be honest and say a lot of he previous discussion (argument :D) was fairly confusing to me, although I get he general gist of it!
So to confirm, the fact that the ball is blocking up 64% of the area of the tube is quite important, and I also understand the terminal velocity factor. Although the fall of the ball in the (see through) pipe was 0.8m, I left space between the ball entering he fluid and my start line for a (nearly) terminal velocity to be met. I suppose this was not enough space, and my terminal velocity is the thinner fluids was wrong. The golden syrup one was a bit different, in the sense that terminal velocity was definitely met as it had so bloody long to reach it.
Hopefully I will have time to do another experiment of some sorts this week, not sure how it will go though!
thanks :D
Well if you had yor start line offset then you definitely did a pretty good job taking account of the initial acceleration. It may be a good idea to offset your finish point since the presence of the bottom of the tube will affect the motion as well but that isn't going to be as important.
The bottom line is that blockage is significant. It will likely offset your results by a certain factor, and while the relationship between all the fluids' viscosities will stay the same (syrup will still be the most viscous, water the least), the values you get will be off. Turbulence won't be an issue, especially in the more viscous fluids, so that blockage will be the primary concern.
I would have to say that your initial results don't look terrible. The syrup seems a bit inflated but that very well may be a blockage issue since I would expect blockage to be more important for the more viscous fluids.
thanks
Out of interest, what is that the blockage actually does to affect motion? I am not questioning you (I'm no Ph.D. studentl!), but I presume the blockage is affecting some sort of flow in the fluid near the bottom of the tube when the ball is traveling down? Is the ball going to speed up or slow down because of this?
yeah my results show the overall trend quite well in terms of relative results, but it is just surprising how off my actual values for viscosity are ... water at 1.45 kg/ms, glycerol at like 25.8 kg/ms, both of which are massively off!
The blockage will affect the system because if the relatively small area that the water has to pass through to get around the side of the ball. Stokes' Law assumes an infinite medium. When the tube is so narrow compared to the ball, it impedes the water's ability to get out of the way of the ball, so you end up with a higher apparent viscosity. I wouldn't expect it to be off by 3 orders of magnitude though.
Something is definitely up, though, because if you do the calculation with the correct viscosity of 0.001 Pas and your parameters, it says that the terminal velocity has to be 1308 m/s, which is just ludicrous.
If you look here, you can find near the bottom a correction for the tube diameter, so at least you don't need a larger tube:
btw, i don't suppose anyone has ever done a similar experiment, or knows where I can find the results of one online (i've done a bit of searching), just something to compare final results with :)
thanks
The number is ludicrous because Stoke's law only applies for VERY low Reynolds numbers. You disagreed with my comments about turbulence earlier and said the flow would separate but not be turbulent. Stokes law doesn't even apply to separated flows, let alone turbulent ones.
For the OP, I would suggest that to get reasonable results you need two things.
1. The tube should be much wider that the ball, say at least 5 times as wide.
2. The terminal velocity should be low, say about 1 cm / second or less.
To get the low velocity in water, you willl need a much smaller ball, and/or a ball with lower density (plastic, or even a hollow ball) so the buoyancy force is greater compared with its weight. In the more viscous fluids you can use a larger or heavier ball to speed up the experiment.
Most "real life" fluid flow is WAY too fast for Stoke's law to apply to it. That's why the Stokes formula is giving nonsense like a terminal velocity more than 1km/sec. The only flow situations where Stokes law applies to "real life" are things like tiny smoke particles drifting in the atmosphere and suchlike.
This, of course, is the correct answer here. Stokes flow is at incredibly low Reynolds number. Forgive me for not thinking all the way through that part, this site is sort of my diversion from everything I should be focusing on right now (finals).
I disagreed with your comments about turbulence because they were wrong. That is a totally separate issue from whether or not I overlooked the fact that Stokes' law only applies to creeping flow because you can have laminar flow that isn't creeping. On top of that, I maintain my assertion that this system would not be turbulent except after it likely separates.
Looking at the glycerol case seems to prove that the creeping flow assumption is where this breaks down. It isn't quite creeping flow, but it is pretty darn close considering the Reynolds number is around 0.8. Stokes' law alone gives something on the order of 32 Pas for the viscosity, but corrected for the wall effects, it gives about 2.4 Pas, a factor of 2 greater than the real value. That is not too shabby considering that we really aren't creeping but we aren't too bad either.
However, look at the corn syrup. I don't know the exact viscosity, but everything I have seen says between 2 Pas and 3 Pas. The Reynolds number here is 0.01, which satisfies the conditions for Stokes flow, and even with a wall correction, the viscosity measurement from his observations are at least an order of magnitude too high. My only thought is to side with everything said before and say that, even with a wall correction factor included, his tube is still way too narrow compared to the ball.
1. What is viscosity?
Viscosity is a measure of a fluid's resistance to flow. It is often described as the "thickness" of a fluid. In other words, it is a measure of how easily a fluid can be poured or stirred.
2. How is viscosity measured?
Viscosity is typically measured using a viscometer, a device that measures the time it takes for a fluid to flow through a small opening. The longer it takes for the fluid to flow, the higher its viscosity.
3. What is Stokes' Law?
Stokes' Law is a mathematical equation that relates the viscosity of a fluid to the size and shape of particles suspended in the fluid. It is commonly used in the study of fluid mechanics and is named after the scientist who first described it, Sir George Gabriel Stokes.
4. How is Stokes' Law used to calculate viscosity?
Stokes' Law can be used to calculate the viscosity of a fluid by measuring the velocity of a small particle as it falls through the fluid under the force of gravity. By plugging in the particle's size, density, and velocity into the equation, the viscosity of the fluid can be determined.
5. What are some real-world applications of viscosity and Stokes' Law?
Viscosity and Stokes' Law have many practical applications, such as determining the thickness of motor oils, measuring the concentration of particles in a water sample, and understanding the behavior of fluids in industrial processes. They are also important in the study of weather patterns and ocean currents.
  • Differential Equations
  • Classical Physics
  • Mechanical Engineering
  • Mechanics
