Pendulum Point of Suspension & Acceleration: Time Period Explanation
  • Thread starter nishant
In summary, the question of whether a pendulum's time period will increase or decrease when its point of suspension is moving upwards with acceleration is a matter of perspective. While some use pseudo force to calculate this, it should only be used when the observer is also moving with the point of suspension. In reality, the acceleration of the pendulum is the determining factor, and according to general relativity, it can be treated as if it were in a gravitational field of "g+a." However, this does not take into account the effects of air resistance. Alternatively, one could use Newton's laws with an inertial frame of reference to arrive at the same result. Overall, the time period of the pendulum can be calculated using the formula T
nishant
95
if a pendulum's point of suspension is moving upwards with acceleration {a},then the time period of the simple pendulum will increase or decrease?{many people are using pseudo force to calculate this question,but that is to be used only when we are also moving with the point of suspension,but no where in the actual question is it written theat way?"
The point of view is not important here. The fact that the pendulum is accelerating is key. General relativity says that we can not tell the difference between the effects of being in a gravitational field and the effects of actual acceleration. If the pendulum accelerates upward, then the pendulum will behave exactly as it would in a gravitational field of "g+a."
Of course this will be ignoring the effects of air resistance.
OK, if you want to prove it the hard way you can apply Newton's laws with the observer in an inertial frame of reference. Vertically, Ty - mg = ma. Use this to determine Tx in terms of displacement and you'll arrive at the same result
[tex]T = 2\pi \sqrt{\frac{L}{g + a}}[/tex]
On the other hand virtual gravity (grav. acceleration = g+a) is a convenient abstraction that you could use.
1. Why is it important to get an answer?
Getting an answer can help you understand a concept or solve a problem. It allows you to expand your knowledge and make informed decisions.
2. Can someone else answer for you?
While someone else may be able to provide an answer, it is important to try and find the answer yourself first. This will help you develop critical thinking skills and improve your understanding of the subject.
3. How can I ensure that my question will be answered?
Make sure to ask a clear and specific question. Provide enough context and background information to help the person understand your question. Also, be polite and respectful in your request for an answer.
4. Why do people ask for multiple "please"s in their request for an answer?
Adding multiple "please"s is often seen as a sign of urgency or politeness. It can also convey a sense of desperation in wanting to receive an answer.
5. Is there a limit to how many times I can ask for an answer?
It is generally best to limit the number of times you ask for an answer. Repeatedly asking the same question can be seen as annoying or disrespectful. If you do not receive an answer, consider asking for clarification or seeking help from other sources.
  • Classical Physics
  • Classical Physics
  • Other Physics Topics
