Is the sum 1+2+3+4+... really equal to -1/12?
  • Thread starter Shaun Culver
In summary, the equation 1+2+3+4+...=-1/12 is a result of Ramanujan summation, which is a formal method used to sum divergent series. This equation was discovered by Srinivasa Ramanujan and has been used in quantum physics, but it is not a true mathematical equality. The equation has been used in string theory and has significance in the distribution of electron orbitals, but it is considered a form of numerology and is not widely accepted in the mathematical community. The equation can be derived through analytic continuation, but it is not a valid way to sum the series.
Shaun Culver
69
How can
1+2+3+4+... = -1/12
Apparently, this series has been used in quantum physics - giving it physical significance! True/False?
Mathematics news on Phys.org
yea that's definitely wrong, that series diverges
it has signifcance to others due to the perception of what they came up with there thought. it seems like you don't want to grant it the same significance the others have.
you asked (how can) so find how meany ways if can't be then find how meany ways it can't be, then compair to what others have said. mainly to bring your self more understanding of what makes it and why its true or false -.- this way you can teach your self the same concepts they were teached by others. anyways... its true in a few ways and false in more... just ask what would make it false or true and why, then you would know how it can and how it can't without being told by others. So i won't spoil your learning of the workings of this world, by just telling you. but i will say a way how you can learn for your self :D
first signt it is wrong: the sum of any real positive numbers cannot be negative.
second: even if the result you posted was positive, 1+2+3+4+... its terms are of an arithmetic sequence and therefore it diverges. so it cannot equal any real number.
shaunculver said:
How can
1+2+3+4+... = -1/12
It's a trick, a trick of notation.
This equation is of historic importance, and comes from Srinivasa Ramanujan (1887 - 1920).
He was basically a poor Indian who didn't have any formal mathematical schooling, so he made up his own syntax. What that series really represents is:
1/(1^-1) + 1/(2^-1) + 1/(3^-1) + 1/(4^-1) + ... + 1/(n^-1) = -1/12
It was a pretty important discovery for analyzing the Riemann zeta landscape, and Ramanujan did the whole thing on his own apparently, which greatly impressed Brittan's Hardy and Littlewood.
As for the quantum physics usage, I believe the distribution in the Riemann zeta looks similar to something with electron distribution.
Thank you. This is elegant. This is profound!
How would you set this series up in mathematica code to give a sensible answer?
http://files.liveadmaker.com/F/11767471/Image.gif
This equation produces an error.
Couldn't tell you, I'm much better at reading about mathematics than actually putting it into practice :(
du Satoy, Marcus . The Music Of Primes: Searching to Solve The Greatest Mystery in Mathematics. New York: Harpercollins, 2004. (p137)
Thank you for the link (Big-T) & the reference (Xislaben). I have read (on John Baez's website) that this equality is important in string theory.
The Stability of Electron Orbital Shells based on a Model of the Riemann-Zeta Function
http://www.ptep-online.com/index_files/2008/PP-12-01.PDF
Sorry, I don't get it
[tex]\sum^n_{r = 1} r = \sum^n_{r = 1} \frac{1}{r^{-1}}[/tex]
Says the same thing to me, unless we define the $-$ sign differently.
I don't see the trick in the notation.
The problem is that you compare the Ramanujan's sum with a normal sum..
Ramanujan summation is a formal way to sum series that would otherwise diverge. I can give only a small example of 'how it works'; I can't even prove the 1 + 2 + 3 + ... example yet.
Let a_n = (-1)^n. Then the series is
S = 1 - 1 + 1 - 1 + 1 - ...
-1+S = -1 + 1 - 1 + ...
Adding the two,
2S - 1 = 0 + 0 + 0 + ...
2S - 1 = 0
S = 1/2
Ridiculous numerology coming from a journal I've never heard of.
Just a cursory glance turns up several factual errors, no real physical justifications, and essentially, the whole paper amounts to the ridiculously shallow observation that the Z of atoms with a single electron in their valence shell (a set of 17 numbers) corresponds to some of the Riemann zeta primes.
The reality is that orbital filling is perfectly well-understood as following from the Pauli principle and allowed combinations of quantum numbers. That sequence is trivially derivable and looks nothing like the Riemann zeta function.
Stupidest thing I've seen all day.
I was under the impression that it was more sum
[tex] S_{p} = \sum_{n=1}^{\infty} \frac{1}{n^{p}} [/tex]
was only convergent for p greater than one. But if you take its analytic continuation of the function then you obtain the result
[tex] S_{-1} = \frac{-1}{12}. [/itex]
So I think it reduces to a question of analytic continuation.
This is what I remember from a course in string theory but at the same time I felt a little strange about it as well.
What is sanity and why does it need to be restored?
Sanity refers to a person's mental well-being, specifically their ability to think and behave rationally. It may need to be restored if a person is experiencing overwhelming stress, trauma, or mental health disorders that impact their ability to function in daily life.
What are some signs that I may need to restore my sanity?
Signs that you may need to restore your sanity include feeling overwhelmed, having difficulty concentrating or making decisions, experiencing intense mood swings, and engaging in self-destructive behaviors. These signs may indicate that you are struggling to cope with stress or mental health issues.
How can I restore my sanity?
There is no one-size-fits-all solution for restoring sanity, as each person's experience and needs are unique. However, some common strategies include seeking therapy or counseling, practicing self-care and mindfulness techniques, and building a support system of friends and family.
Is restoring sanity a one-time process or an ongoing journey?
It depends on the individual and their specific circumstances. Some people may find that restoring their sanity is a one-time process, while others may need ongoing support and treatment to maintain their mental well-being. It is important to prioritize self-care and continue seeking help if needed to prevent future relapses.
What should I do if I am struggling to restore my sanity?
If you are struggling to restore your sanity, it is important to seek help from a mental health professional. They can provide personalized support and guidance to help you on your journey towards mental well-being. It is also important to reach out to loved ones for support and to prioritize self-care practices such as exercise, healthy eating, and relaxation techniques.
  • General Math
  • General Math
  • General Math
  • General Math
