Plinko Launcher
  1. Dec 4, 2011 #1
    I am trying to create a plinko launcher for my plinko board (as you would see in the price is right). I created a pinball type spring launcher and used a bell crank in order to change the horizontal force into a vertical force. I am using a 3.5in spring with a spring constant of 1.09lbs/in. I plan on having about 2 in of compression which results in a spring force of 9.697Newtons.
    I want to ensure that the plinko will make it up the board and into its appropriate slots. I am having trouble coming up with right calculation in order to prove that the plinko puck (4oz or .2lb) will make it up the board. I also was wondering if anyone had any input of how to come up with the appropriate angle of the curve in order to ensure the plinko will make a smooth turn. Thank you all so much for your help.
  3. Dec 4, 2011 #2
    I would get the work done by the spring, and then that will give you the KE of the mass.
    ∫f(x)dx gives you the work done by the spring
    I converted to metric and here is what I got
    f(x) = 190.88x
    so the integral is
    ∫0 - .0508 95.44x2
    gave me ≈.246J
    If it is launched vertically you should subtract gravity .89N(gravity on puck) * .0508m = .045J
    .246 - .045 = .201J Which should be the KE of the puck when it leaves the spring.
    If I did my math right that will only give you .23m(8.9in) of height. So depends on the height of your board, and if it contacts anything on the way up(slides up a slanted surface or anything) You should also subtract the work done by friction.
  4. Dec 5, 2011 #3
    Thank you for the quick response! I am going to give this a shot and see what I can come up with.
    I realized that I will need much more height than that so I think I am going to try a spring with a different K value. Unfortunately the launcher has too be place within tight constraints so I can't increase the x value for compression.
  5. Dec 5, 2011 #4
    One more quick question...Once i find my Kinetic energy how do I determine my maximum height?
    Do I find the initial velocity first and then use gravity as a negative acceleration?
  6. Dec 5, 2011 #5
    Just find the potential energy in the spring before it is released,
    [tex] PE = \frac{1}{2}kx^2 [/tex]
    Where [itex]k[/itex] is the spring constant and [itex]x[/itex] is the distance it is compressed. This value is then equal to,
    [tex]mg(h - \cos (\theta) \mu d) [/tex]
    With [itex]m[/itex] being the mass of the puck, [itex]g[/itex] being the gravitational force, [itex]h[/itex] being the height that it moves up, [itex]\theta[/itex] being the angle of any surface the puck moves against measured from the ground, [itex]\mu[/itex] being the constant of kinetic friction for the surface and the puck and [itex]d[/itex] being the distance it moves along this surface.
  7. Dec 5, 2011 #6
    Awesome, thank you! I was able to figure out my calculations from all of your help :)
